Question about JVC HR-S9500 S-VHS VCR
When powered on thr tape transport mecanism does not slide in place. Yhe xassette conot be introduced
Tape transport failure on tc-366, motor noise but no tape movement
These units are mechanically in need of a good cleaning and application of new grease in the slide plate mechanism. The Play idler that was in the last one i rebuilt was sent off to Terry'srubberrollers.com to have it get new rubber on it. There is certainly a lot of work to be done on these units but they can be made to work again. Personally though, I would just get a Teac A2300S or SX and use that as the overall maintenance and longevity will be better in the long run. I have serviced hundreds of them and I still do. The design of the Teac is not so much dependent on all kinds of mechanical parts as the Sony is. The last TC366 I worked on took about 4 to 5 hours to correct all it's problems. Then when you are done you still have a lever activated deck where the Teac is a solenoid deck with remote capability. I worked at both Sony factory Service and Teac Factory Service so I have had experience in each item.
Aug 24, 2012 | Sony Audio Players & Recorders
TA-RW255 DUAL CASSETTE DECK
Have you check and make sure that the belts are working well?
Is the pinch roller working (spinning)?
A worn out belt will make the mechanism not to operate properly resulting in shutdown to avoid damage to the tapes.
Apr 11, 2008 | Audio Players & Recorders
TAPE MECHANISM WON'T ROLL THE TAPE, IN EITHER RECORD OR PLAYBACK
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Apr 02, 2012 | RCA CC4393 VHS Analog Camcorder
Service error 6000. Cartridges won't slide to the left
4. PRINTER TRANSPORTATION
This section describes the procedures for transporting the printer for returning after repair, etc.
1) In the service mode, press the Power button to finish the mode, and confirm that the paper lifting plate of the sheet feeder unit is raised.
2) Keep the print head and ink tanks installed in the carriage.
[See Caution 1 below.]
3) Turn off the printer to securely lock the carriage in the home position. (When the printer is turned off, the carriage is automatically locked in place.)
[See Caution 2 below.]
4) To further secure the carriage to prevent movement from the home position during transportation, make and use a fixing tool in the following procedures:
i. Fold an A4-sized paper 5 times, and wrap it twice with tape, as shown in Figure A below (to prevent the fixing tool from caught into the inside of the
printer).
ii. Insert the fixing tool between the carriage and the main case unit, and securely fix it with tape, as shown in Figures B and C below.
Note: The tape should be similar to the polyester tape used at shipment, which will not easily be torn or removed, or leave adhesive on the unit when
removed.
Leave a sufficient length of tape to fix the tool so that the tape end is easily seen even when the cover is closed, so that the user will remove the
Aug 23, 2011 | Canon Pixma iP6210D InkJet Photo Printer
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
When opening camera to insert tape,tape tray slides out,does not
This is new for a sony camcorder technician. Here is what you should do. There may be a sticky substance holding the side tape door to open then the whole tray will go back down. Using battery, press the eject button when the tray is all the way up, disengage the battery to turn the power off. This way you will have the tape tray at posititon just before the opening of side door. With you finger nudge the door outward to see if it is just got stuck by substance. Using Q-Tip with some "windex" go around the edges of the tray. You can also take the door off by removing two screws. -James. For additional assistance by email, go to www.camerarepairjapan.com
Apr 02, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Getting error "E03 unit in safeguard mode" on JVC GR-D200U video camera
The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the norma
Nov 24, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Cassette Compartiment Problem
We have this service manual. Pl. email me.
Sharmila.
Aug 24, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
JVC HR-S9500 S-VHS VCR Logo
88 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
