Question about Anycom Aris21 Bluetooth Headset Wireless Headset
Bluetooth doesn't charge - Anycom Aris21 Bluetooth Headset Wireless Headset
Getting ipod5 =bluetooth
As long as Bluetooth is on in your settings and the devices are close enough to "pair" it should work without typing anything. If its still paired to your iPad, try Turing it off on it and see if that works. It should not make a difference but signals can be strange. Also check to see if the Bluetooth you have is compatible with the iPod. Some aren't. Good luck, Anthony
Jun 19, 2013 | Cell Phones
Motorola H710 Bluetooth Headset will not turn on!
I have the exact same problem with my Motorola H710 Bluetooth Headset. When I charge the headset a green light is displayed. After the charge is complete I unplug the headset and NO light is displayed. I flip open the boom and NO light is displayed. I hold the call button for 10 secs or 10 mins or 10 hours and NO light is displayed. There is suppose to be a blue light displayed to indicate that the headset is ON. Since there is NO light displaying that means the headset is OFF. So my headset DOES NOT TURN ON! I did my research no where online can anyone give a solution. All the above solutions given does not help because the blue light DOES NOT turn on. No user guide or customer service rep or tech support can help that is what I found out. So I guess I will toss my headset in the garbage!
Nov 26, 2011 | Motorola Mobility H710 Bluetooth Headset
Does my siemens lifebook c6555 fujitsu have bluetooth?
Hello Darren,
Sorry, but it doesn't have a Bluetooth.
Nov 03, 2011 | Acer Aspire 5535-5050 Notebook
Whats the best way to charge the bluetooth parrot b250-xt
It doesn't make a difference if you use the car or house charger. When the green light comes on, it's fully charged. If you are having a charging issue, you can try installing a fresh battery. I have been in contact with the overseas supplier of these batteries and am offering them for $20 via PayPal once my shipment comes in. Please contact me at ebhammonds@gmail.com.
Oct 26, 2011 | VXI Corporation Blueparrott B250-XT...
My plantronics bluetooth headset will not charge when plugged in
It can be one of a few reasons. First, you want to make sure that you have a good power source. If it's not charging, it could be your cord or phone. Normally the AC adapter has a light to indicate it has power. If that's the case and you have a good connection between cord and phone, and your headset still doesn't light up at all after being on the charger, it's time to take it back to your retailer and get it replaced. If they refuse, you can call Plantronics at 800-544-4660 x5 x5538 for warranty assistance.
Good luck from Headsets Direct!
Sep 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
Blinking red while charging? will not turn on when unpluged
On the back of the headset you'll locate the power button. Turn off your headset before charging. It should glow red while it's charging. If it still doesn't come on, it's time to see your retailer about getting it replaced or call Plantronics at 800-544-4460 x5 x5538 for service.
Jul 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
My cell phone doesn't charge, gets hot, Bluetooth
What type of phone are you seeking help for?
Jun 08, 2011 | LG Cell Phones
The blue and red light doesn't. Come on at all
First, make sure to charge the unit for a few hours. Next, try pairing with the following link:
How to Pair Plantronics Voyager Pro Bluetooth Headset
If it still doesn't enter pairing mode, the unit is defective and needs to be replaced. It comes with a 12 month warranty. Contact your supplier to receive a replacement.
Good Luck from Headsets Direct!
Apr 27, 2011 | Plantronics Voyager PRO Bluetooth Headset
This unit will not charge
If you try with another Motorola mini US plug charger and headset still doesn┬┤t charge, it means that the internal headset battery needs to be replaced, maybe is less expensive to buy another headset than to change the internal battery of the one that you have.
Mar 05, 2011 | Motorola Mobility H371 Bluetooth Headset
The mad catz blue tooth mic #8860 wont charge how can i fix it?
Try to charge it on a USB on the PC, If the red light doesn't stay on, meaning it's charging, then you have a faulty headset and you'll have to contact your retailer to ask for a replacement.
Unfortunately this is a know issue with this headsets...
Hope it helps
Mar 02, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Anycom Aris21 Bluetooth Headset Wireless Headset Logo
23 people viewed this question
Top Anycom Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
ray gallant
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
