Question about KitchenAid Architect ® II KEBS208S Electric Double Oven
KEBC208KSS04 doors won't close completely. Already had someone out that changed both hinches.
Oven door springs won't close door properly
get an engineer to change the springs for you.
Dec 15, 2011 | Ovens
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
Dec 04, 2011 | Thermador Professional Series PO301...
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
I turned on the self clean and as the door was locking I thought I better check and make sure there was nothing in there, and opened the door. Now the lock is stuck out and the door won't close and the...
Push the locking bar back manually , close the door and restart the clean cycle. Let the cycle complete and the mechanism should right itself.
Sep 01, 2010 | Ovens
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
Oven door will not close completely no tension.siemens 6 hob.
I told bosch which is the same as siemens that the door hinges are defective. I even told them how to fix the problem without changing the hinges .If you add three washers on each hinge this will bring the door in to close the same for the bosch ranges. ps ex tech:)
Feb 24, 2010 | Ovens
Oven door will not close completely stays open about 1/4 inch
Hinges may need to be replaced. Rule of thumb, if one is changed, change the other as well. Also try WD40 open and close continuously, it may be stuck. But you will eventually have to change the hinges. Good luck.
Sep 03, 2009 | Bosch Ovens
KitchenAid Architect ® II KEBS208S Electric Double Oven Logo
105 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
