Question about Philips 47PFL7432D/37 TV
When plugging in, blue light comes on for about 5 sec and goes out. Approx every 20-30 sec you can hear a relay click. No picture. When un-plugging the screen will flash blue.
  • bobt317 Nov 13, 2010
    I am not familiar with the current LCD TVs but have some experience with CRTs. At one point while determining the symptom it flashed an error code of 63 on the red LED. This has not re-occurred. The unit was troubleshot by the previous owner and they told him that in might be the inverters. He figured that it would not be economical to repair. i unplugged the inverters and had the same symptom. Nothing is overheating, what looks like a processor chip only got up to 80 degrees F. i am just taking shots in the dark to see if I can remove and replace a board and earn a cheap TV. So if you can suggest where I might narrow it down I would appreciate. it. I was also able to find a service manual for this but have not had time to go through it. Thanks.
  • Philips Master
  • 11,800 Answers
If the screen flashes blue it means that the inverters are operational. And since you get error 63 which signals a Mips protection it means that the power source is just fine and has been shut down by its own protection because there's a shot on one of its outputs.
To find out which board is defective you must check the voltages on the psu outputs. Start with the ones powering the mainboard, followed by the T-con board.
Posted on Nov 14, 2010
  • Philips Master
  • 12,061 Answers
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Posted on Nov 13, 2010
  • MENDEZ1974 Jan 11, 2011
    HI I HAVE A Philips 47PFL7432D/37 TV AND THE POWER WENT OUT AND IT DID NOT TURN BACK ON IT MAKES LIKE ITS TURNING ON AND THE BLUE LIGHTS COME UP AND THEN FEW SECONDS LATER TURNS OF NO PICTURE AT ALL. HAD IT CHECKED THE GUY SAID IT WAS POWER SUPPLY I BOUGHT THE POWER SUPPLY AND IT KEEPS DOING THE SAME THING.... ANY =NE THAT COULD RELATE WITH THE SAME PROBLEM THAT COULD HELP
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
Not staying cold
tell me do you hear a buzzing sound for about 5 sec ending with a click sound. every so often?? if so then you have a start device (relay) problem on the compressor you may think the unit is running b/c the lights are on and fan is on but if you hear that noise coming from the back of the unit while turned on then its the start relay or worse case the compressor is locked up..9-10 though usually its the start device
Mar 15, 2012 | Kenmore Side by Side Refrigerator
Turn it on yesterday and i can hear a clicking noise for approx 5 secs then the standby light comes on and no picture. any advice, or reccomened repair
1st POSSIBILITY.....usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ( in some TVs ''garrrr'' like sound comes - that sound is from EHT.... but it is rare....some times ''click click'' sound comes...it is from relay switch ) ..... but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ................ 2nd POSSIBILITY - main capacitor (very big in size) is blowing off...................... - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) & price of capacitor will be between Rs.50 ( US$ 1) to Rs.150 ( US$ 3) ..........iam from bangalore.....i have no idea about component's price & service charge in your area.....this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact panasonic service centre
Apr 16, 2011 | Panasonic Televison & Video
I plug it in and I hear a clicking inside over and over and the power light blinks then goes solid the clicking stops a sec then it repeats the cycle again. Doesn't matter what I press just keeps doing the...
that clicking noise is a relay. there seems to be some problems with the power supply. it is not getting enough voltage. possible capacitors gone bad. inside power supply
Oct 31, 2009 | Zenith C32V37 32" TV
Compressor will come on for approx 3 sec and then go off with click and 8-10 sec. later try again
The start relay device on the compressor is faulty. replace this start device asap.
May 26, 2009 | Kenmore Freezers
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 47PFL7432D/37 TV Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
