Question about LG LFX25960ST Stainless Steel French Door Refrigerator
I need a part number for the hose that gets connected to the water line for a lfx25960st an lg french door with bottom freezer drawer
  • LG Master
  • 8,220 Answers
The freezer bottom slowly filled with water which froze.
the unit is not defrosting due to open heater element ot bad timer
Feb 22, 2010 | LG LFX25960ST Stainless Steel French Door...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Lg bottom freezer with ice. Need to find out
Remove the rear acess cover.
The drain tube is on the right side next to the condensor fan assy.
Jan 08, 2010 | LG LFX25960ST Stainless Steel French Door...
Water is dispensing very slowly and I just
yup,
i would turn your freezer down a few degrees, you are more than likely expeiancing, whats called migration frost, cold air from the freezer, could be freezing your water resivoir or the line from it
causing bad pressure
Oct 19, 2009 | LG LFX25960ST Stainless Steel French Door...
I have a brand new LG bottom/slider freezer and I am trying to hook up the water supply for the ice machine to the cold water supply under my kitchen sink. I have purchased a kit inculding a copper pipe...
well I had a plumber connect a new hose it cost me $ 85 but it was properly install, since we added a splitter Home depot recommended but it can't take the pressure and the hose connector will leek. or if you are handy connect a splitter and a new valve
Oct 06, 2009 | LG LFX25960ST Stainless Steel French Door...
My Bottom freezer refrigerator with ice maker has ice built up and a thin layer of ice covers the base under the drawer. Could the tip of the pipe that fills the ice mold have frozen creating preassure and...
there should be a drain at the bottom under drawer. I suspect that it is obstructed. When unit goes into defrost mode ice melts and refrezzes due to obstruction
Sep 29, 2009 | LG LFX25960ST Stainless Steel French Door...
Door display shows eror code FF
This means your freezer fan is not working and you'll need to replace it. It's one or two small plastics fan that sits behind your freezer drawer. It's located behind one of the two wall panels behind your freezer drawer. They circulate the air flow throughout, one for your refridgerator and the other for freezer. I had to have both replaced and now my line holder in the bottom back right side of my refrigerator is leaking, so I had to shut off my water until we find the part number. Good Luck! I know I'll need it because my wife has all LG in the kitchen including a flat T.V and 2 microwaves.
William,
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Ice under freezer drawer
Hi, Check in the back rear of the freezer and se if you have ice built up. MOST cases the defrost drain gets plugged behind the rear freezer wall under the evaporator.
Please let me know if I can assist you further.
Thanks
Vic
May 26, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
101 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
