Question about Dryers
Maytag mdg3000aww Makes squeaky noise when in use
  • 246 Answers
Here we go. First unplug the unit. Remove the front panel by removing the 4 phillips screws just inside the door (on the hinges and just opposite). Next remove the greenish/ brown 5/16 screws that hold the front panel in. There are wires still connected (door switch and moisture sensor) but if you swing it to the side, you can leave them connected and still procede. Next, you have to reach underneath (very difficult to see this so you will have to do it by feel) There is a belt that wraps around the drum. On the underneath side of the drum as you follow the belt it wraps around the motor pulley (small wheel) and the tensioner pulley (bigger wheel just to the right). Now with one hand, move the larger pulley towards the msaller one. This will give you slack and you can take the belt off both pulleys. Now pull the drum
forward. There you have the inner workings left. Now, there are 3 wheels. 2 black and 1 white. Your squeeking noise will be coming from the one that doesn't turn freely. You can get the replacement wheel from your local appliance parts store or on line from the manufatrues web site. However, if you do have to wait for the part, take the wheel off the shaft and wipe off the inside race of the wheel and the shaft for temporarily
relife and useage.
Posted on Jun 21, 2008
Brand new maytag dryer works but makes noise
Could be something in the blower housing or maybe a loose blower. It might be a bad wheel though if you used the incorrect venting or your vent has a restriction that would cause overheating.Usually the wheel closest to heat source begins to squeal. Ever hear the old say the squeaky wheel gets the grease?
Oct 26, 2011 | Dryers
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked...
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
Feb 20, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
Aug 03, 2009 | Dryers
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My dryer is making a very loud squeaky noise. Is is the motor or something else?
Not the motor if it's still working. The noise is coming from the bushing that hold the drum in place.
Apr 05, 2009 | Maytag Dryers
My dryer makes a loud squeaky noise when it is in operation
opne the backwall from ur dryer and replace belt.....go in touch with maytag and ask them for a new manuel to send to you
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dry stops working
sounds as if the thermal protector is shutting down the motor due to overheating. time for a new motor
Nov 23, 2007 | Dryers
Dryers Logo
3,109 people viewed this question
Top Dryers Experts
