Question about Sonos Controller CR200
Hi. Can anyone help me ? My Sonos CR200 doen't turn on.. I have removed the battery for 15 min. and still it doesn't work.. No lights no nothing :-)
Controller cr200 won't turn on
Have you tried taking the battery out and putting it back in? If not, that is the first thing I would try. If pulling the battery and putting it back in and then charging it does not resolve the issue then I suggest contacting Sonos Support.
Nov 13, 2013 | Sonos Controller CR200
Car Won't Work. HELP!!!
did you check battery could be death.Gas pedal is moving,under steering wheel any wires damaged.It is full park position.
Apr 30, 2013 | 2002 Pontiac Grand Prix
Sonos controller touch screen not working
They're phucked.. This failure is common. Sonos should recall the whole lot.
Feb 04, 2013 | Sonos CR200 Touch Screen Remote Controller
Turn off demo mode for sonos
how do i unlock my sonos controller from demo mode
Jul 16, 2012 | Sonos Control System Cr200 Multi-room...
Rear lights won't turn off in corolla 2000
Is this brake lights or tail lights? If brake, then switch on pedal is stuck, if tail lights, then switch is bad.
Jun 18, 2012 | 2000 Toyota Corolla
System keeps dropping out
Can you be more specific I would love to help.
Jan 20, 2012 | Sonos CR200 Wireless control of your Sonos...
2006 hard starting will not stay running, then no power at all.
What happens when you turn the key?... is there a clicking or clunking noise?... try tapping the starter and the solenoid that is attached to the starter and see if that helps. It may help if you have someone else turn the key while you tap on the starter and solenoid.
May 06, 2009 | 2006 Dodge Ram 1500
Sonos won't play when attached
Attach the analog RCA output of the Sonos to the CD input of your receiver. On the receiver select CD is the input. Now turn the volume up on both the Sonos and the Receiver. Dont forget to make sure some music is playing on the Sonos.
Good luck
Dec 18, 2008 | Harman Kardon AVR 300 Receiver
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
Oct 11, 2008 | HTC P3300 Smartphone
Sonos Controller CR200 Logo
209 people viewed this question
Top Sonos Televison & Video Experts
Electro Med Services...
Are you a Sonos Televison and Video Expert? Answer questions, earn points and help others
