Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere 135s won't start briggs and stratton 22 hp engine it is getting spark and fuel and I just put new plugs in because the looked fouled.
  • 293 Answers
There are four reasons for fouled spark plugs, 1, You have a resticted air flow ( dirty air filter, or partially engaged choke), so the mixture is rich all the time fouling tghe plugs. 2, You have a poor quality fuel ( old, stale ), and it wont combust/burn hot enough, then fouling the plugs. 3, You might have a piston ring failure causing engine oil to be left on the cylinder wall instead of being wiped back down, and then burning as part of the combustion process. Thus burning and causingg a rich condition again, and fouling the plugs. Then finally number 4, low engine compression. This is again caused by worn cylinder walls and worn piston rings, causing compressed air/fuel mixture to leak past the rings into the crankcase, and when the fuel/air mixture is compressed then ignited, some of the air needed to ignite the fuel has escaped, and thus a rich condition again, fouling the plugs.
Determining which of the Four are causing you fouling is your next step.
Hope this helps
Posted on Nov 13, 2010
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 22 HP V-Twin won't start
Take it back , it is still under warranty if you just bought it.
Jul 25, 2009 | Garden
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
315 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
