Question about Onkyo TX-SR605 Receiver
Sound problems I have a combo DVD/VCR player (GoVideo) hooked into the Coax1 input on the receiver (per manual recommendations). Also, because I do not have cable, I have the TV antennae hooked into the DVD/VCR player. The TV has no audio out. When I play a DVD, I hear sound fine. However, when I play a VCR or the TV, there is no sound. I tried all listening modes, and I tried plugging the DVD/VCR into Coax2 and using the CBl/STL input selector, all with the same results. Before I got the receiver, the audio went straight from the DVD/VCR player into the TV and I had no problems. Any suggestions for why I cannot hear the VCR or TV? Thanks.
  • Sleep or Not Jun 24, 2008
    Thanks. We will give this a try.
  • 151 Answers
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 20, 2008
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
Can a Go Video 3140 make a dvd disk copy from vcr tapes
Yes,read ur manual intructional book how to hook up the tv, VCR/DVD sides togother so it all link up.Play a VCR tape one side and record a DVD disc another side.
Nov 08, 2010 | GoVideo Go Video DVD/VCR Combo
Need help hooking up cable to Receiver'
connect any cable (from outside) to receiver..from rec to govid...and from govid to tv...
Jun 27, 2010 | GoVideo Go Video DVD/VCR Combo
I have Directvhd and a Govideo 1140 combo. When I tried to play a dvd on input 1 get the movie with no sound, if I go to input2 I get the sound no movie it says progressive scan.
make sure the audio (red, White) is connected to input 1 and the video (yellow) is also connected to input 1. It should be labeled for indentification. Your video is on input 1 but your audio is on input 2 and vice versa. Check your connections again. Make sure your using the red white connections on input 1 for your audio and the yellow for the video on input 1. The above also applies to input 2.
Apr 23, 2009 | GoVideo DV1140 DVD Player / VCR Combo
GO Video DVR4000
www.devicemanuals.com/guide/VCR/GoVideo/GoVideo-Product-Manual-DVD-VCR-DVR4000-TkRjMU1EQT.html THIS SITE HAS THE COMPLETE MANUAL IN PDF FORM.DOWNLOAD & PRINT.(INSTANT USERS GUIDE!!!!!!)HOPE THIS HELPS
Nov 05, 2008 | GoVideo Go Video DVD/VCR Combo
Magnavox dv225mg9 dvd/vcr player. Hooked it up to TV/Cable receiver/combo and I get great dvd reception sound and picture, but on the vcr I get only sound
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Sep 30, 2008 | GoVideo Go Video DVD/VCR Combo
Manual for dvr4400
are ppl still buying govideo ..i heard its a piece of shit?
Jan 26, 2008 | GoVideo Go Video DVD/VCR Combo
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
Onkyo TX-SR605 Receiver Logo
168 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
