Question about Sony Playstation 3 (PS3) Console
My ps3 system fails to find the ip adress, even tough it recognizes the wireless network
    Guru:
  • Sony Master
  • 2,178 Answers
Try re-entering the wireless access number again by disconnecting from the network and re-entering the correct number.
Posted on Nov 12, 2010
Testimonial: "great.thank you."
I have a ps3 ip's adress problem i have a belkin wireless router and when i turn on my ps3 it wont sign in so i go to test conection and it waits and then it says id's adress failed
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Error code 8002ad23
Hi Giles
You probably have your router connected to your modem, and a PC connected wired/wireless, and the ps3 connected wired/wireless.
1. First you need to start your ps3 system. Go to your network settings and select information. Write down your IP, Subnet mask, Standard Gateway, and the primary DNS.
2. Start your PC and go to your networks settings. Right click your network adapter, click properties. Select "Internet Protocol version 4 (TCP/IPv4). Click properties and type in manually the IP adress, Subnet mask, Standard gateway and DNS.
Then you click "Advanced" and then you click "WINS" then "Activate NetBIOS over TCP/IP". Save your settings and connect the ps3 to your network (should not make a difference if you do it wired or wirelessly)
Let me know if this helped and please do rate my solution.
Regards
KreativeGeek
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
Trying to connect my dynex router to ps3 keeps asking for ip adress can u help
PS3 might not be getting the IP address from the router /
Is your wireless network secured network ?
Make sure that you are typing the correct network key .
check the wireless settings of router.
Click Here for step by step solution
Oct 31, 2009 | Computers & Internet
Subject: my ip adress
The Wireless Security might be enabled in your wireless network. Check the wireless settings of your wireless router (encryption or wireless MAC filter). If the wireless settings are correct, you may try to manually assign a static IP.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Can't get network connection to work.
Are you trying to connect to the Internet using a wireless router or vai a network cable?
Have you got an Internet Service Provider and does your computer have trouble connecting to the Internet?
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Internet Connection
On the X-Cross Media Bar, (the menu that comes up when you turn on the PS3) under "settings", go to "Network Settings".
then go to "Internet Connection Settings". select "yes".
go to "custom", "Wireless", "Scan".
If your network is not listed, move your PS3 closer to the Wireless Access point.
Select your Network and enter your password (if it needs one).
select "automatic" for everything.
select "Test Connection".
the "Obtain IP Adress" and "Internet Connection" should say "Succeeded".
If not, contact your system or network administrator or a teacher that knows a lot about computers.
Aug 17, 2008 | Sony Playstation 3 (PS3) Console
OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
Nov 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
225 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
