Question about Apple iPod touch
It keep saying ipod is disabled - Apple iPod touch
Have you tried plugging it into the computer via usb? otherwise go to an apple store, i'm sure they have a solution.
Posted on Nov 12, 2010
Ipod disabled
The IPod say 'Disabled try again in 23,257,464 minutes. It wont let me do anything/
Jan 04, 2014 | USASPEC PA12-BMW iPod Interface with Text...
Password forgotten now say's disabled
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Jul 30, 2013 | Apple iPod touch
What is wrong if my ipod says its disabled
it usually happens when you type your passcode a certain amount of times incorrectly. it should say how long its disabled if it does just wait that amount of time
Nov 26, 2011 | Apple iPod touch
Ipod is disabled try again in 21million minutes
yes well there is no way to keep ur apps but you can do this(must be plugged into the computer-
  1. turn off ur ipod
  2. while it is turning off hold the only 2 buttons
  3. it will when the apple comes up let go of the button on top
  4. finally you will then get a ipod error saying connect 2 itunes
  5. restore ur ipod and done by the way if u want free apps msg my yahoo- ethanshannonf@yahoo.com
thanks!!!!
Apr 29, 2010 | Apple iPod touch
HELP i forgot my apple ipod toches password and it
You will need to do a 'Hard reset' !
This is how the the procedure goes for the ipod touch:
- While plugged into ITunes, Hold down the power and home keys down for 10+ seconds. - - Screen will go black
- Release the power button but keep holding the home key until itunes says 'We have detected an itouch in recovery mode'
- Restore as normal via iTunes
Hope it helps!
Dec 24, 2009 | Apple iPod touch
If just says ipod is disabled try again in 4984418
i have an itouch... when i turn it on it just say ipod disabled try again in 20967586 what do i do?
Dec 08, 2009 | Apple iPod touch
I want to know how to unlock my ipod touch it keeps saying its disabled and to connect it to itunes and i do it and it does not do aney thing
probally you have a passcode and you put the wrong code in alot of times and what that does is it lets the ipod know that it isnt your ipod so it disables and for a period of time.restore it and sync your songs back in
Oct 06, 2009 | Apple iPod nano
My iPod Touch is disabled/"Powned" and I have no clue how to fix
Your ipod has been jailbrokan and apple has detected that so they disabled it.
Jun 13, 2009 | Apple iPod touch
8GB iPod Touch Disabled
Hey,
read this page i posted
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Let me know if you need anything else.
Thanks,
Ekse
Jan 20, 2009 | Apple iPod touch
Ipod touch is disable
Try restoring the firmware, WARNING, this will wipe everything
Press and hold the power button to boot off the ipod, when it's off, press and hold both the home button and the power button for 10sec and release only the power button while continuing to hold the home button, this will put it into restore mode. Connect it to itunes and i tunes will restore the firmware wiping all data and that passcode.
Jan 15, 2009 | Apple iPod touch
Apple iPod touch Logo
26 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
