My BB Storm just recently developed the problem of shutting all by itself. The battery is fully charged & a battery re-boot works until you replace the cover, then it shuts off again.
Also, if I use it without the cover on the unit the screen doesn't click up and down. I need to use it with the screen facing down to be able to type without having to shake the unit...
hi. sounds to me like the ribbon has worn out. if you can repair this yourself check ebay for a new ribbon or contact blackberry support website as it should be under guarantee...
SOunds like your battery is bad. try discharing it :
Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
Take out your battery and slide it into your battery charger.
Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
If the battery has gone flat before you started re-charging it, the phone has turned itself off.
Let it charge for 5 mins, then hold the red button down until you see it re-booting. You can use it while its charging.
Sometimes the cellular phone receiver does not come on when it reboots, if the battery isn't charged enough - when you make a phone call it will let you know and ask to turn on if the battery is charged enough.
Store it in the special holster it came bundled with - when you put the phone in the holster it has something that turns off the display to save battery (phone still on) and other useful things like activating vibrate mode.
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Skype will be avail for BB Storm any day now, in June, coming from Skype the vendor itself. Until now iSkoot for Skype does the job (yet you need to pay airtime fee, local, which is still not too bad Vs Int'l call!)
