Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Doesn,t display on moniter
Hi everybody when i start my pc there is doesnt dispaly on screen is there any bios problem or bios problem all working fine but speaker sometimes beeps plz solve my problem and give me feedback
    Sergeant:
  • 284 Answers
Try reseating the memory chips or video card
take the card out, anything that loose.
if beeping occurs means something is loose.
the memory might be bad too.
Posted on Jun 18, 2008
My computer moniter take more time for switch on the moniter .it doesnt show the windoes logo it directly shows the desktop after taking more time like 5minutes.
its becuse your post bios screen is hidden you can veiw them by clicking tab on the keyboard when the printer starts it will show the post bios details
Jul 03, 2011 | Computers & Internet
Hi, Computer is not able to start because its not able to perform POST. CMOS/BIOS is not starting.Nothing displayed on monitor when starting computer. I had reinstalled XP then when i had reset BIOS...
bad leads
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive they probably be faulty
hope this helps good luck
Sep 07, 2010 | Intel D850MV Motherboard
There is a led lights on but there is no display.but the hdd is working and the processor fan is working
Check for post message , check display screen in bios try reseating the lcd cable if you can before you buy another LCD dispaly
Aug 09, 2010 | Computers & Internet
I turned on my laptop and its on but the screen doesnt dispaly anything, how should i fix that
hi, im nathaniel.
Im going to display the troubleshooting image of the black screen display,
Apr 29, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Dell latitude d60..the laptop wont display without external monit
Seems that you have a loose LCD screen cable connection. You will need to disassemble the laptop & make sure the LCD screen cable connection is tight.
Please check this link for more details:
http://www.laptopparts101.com/lcd-screen-video-cable/
Feb 23, 2010 | Dell Latitude D600 Notebook
Moniter's display related problem
Try reinstalling your video card drivers. if this doesnt work try to degauss your moniter.
Jul 25, 2009 | Lenovo IdeaCentre K210 - 53133BU PC...
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Won't turn on
reset the bios jules
Apr 23, 2008 | Intel Motherboard
Compaq FP 5315 Moniter
Have you checked the computer bios?
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
  1. Turn on the computer and press the keyboard key that enters the BIOS Setup screen key when the keyboard light comes on. The key to enter the BIOS should be one of the following:
    • HP and Compaq desktop computers that came with Windows Vista, press F10 .
    • For HP Pavilions desktop computers that came with Windows XP or previous versions of Windows, press F1 .
    • Compaq Presario desktop computers built after 2002, press F1 .
    • Compaq Presario desktop computers built prior to 2002, press F10 .
  2. Wait 5 seconds.
  3. Press the F5 key to restore the default settings of the BIOS.
  4. Press Enter to accept the change and wait five seconds.
  5. Press the F10 and then the Enter key to save the changes and exit from the BIOS.
  6. The monitor should now display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
  7. If a BIOS update was not available or the monitor is still blank, continue to the next step
Reseating loose internal components
If the PC case was recently serviced or moved, a card, cable, memory module, or processor may have become loose. When this happens, the PC might make a beeping sound when turned on. Use the following steps to check for loose components: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. With the power cable removed press the Power button on the front of the PC for 5 seconds.
  3. Remove the screw(s) that retain the panel or cover from the rear of the PC. c00371492.jpg
  5. Gently press down on the outside edges of cards and memory modules that are inserted into the motherboard to better seat them. Do not press too hard.
  6. Gently press down on the connectors of the flat ribbon cables to seat them.
  7. Replace the side panel and screw(s), reconnect the PC cables, and turn on the PC on.
  8. If the monitor still displays a black screen, the video hardware may be faulty and needs to be replaced or serviced. If the monitor displays the first startup screen but does not display Windows, continue to the next step.
Try this and if it doesnt work. please post again.
Oct 21, 2007 | HP Compaq FP5315 15" LCD Monitor
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
