Question about Technics SA-AX710
Our SA-AX7 says overload. What do we need to do?
    Guru:
  • 2,178 Answers
Do not continue further. There is a short circuit in the power supply or output amplifier stage. Disconnect power. The unit is preventing a fire or further damage to the system. Also, check the speaker output terminals for wires shorting the terminals together. Otherwise, an audio repair shop must isolate the problem. More than likely a transistor has shorted in the output stage.
Posted on Nov 12, 2010
Works fine at low volume, shuts off at maybe one third volume
This sounds like the cooling fan has failed, that's what causes the amp to shut down, because if it didn't, it would over heat, that's why the amp shuts off for safety of fire, because the cooling fan only operates in high volumes only, so I recommend replacing the cooling fan, because that's what's the cause, make so sure you order the right correct fan.
Jan 22, 2014 | Technics SA-AX7
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
How do i turn off the front panel lights?
First on the remote control, press the muting, then press the display button, do this with in one to two seconds, then the blue lights go out, and to turn on again repeat the same sequence.
Sep 29, 2011 | Technics SA-AX7
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Technics SA-AX7 OVERLOAD problem
hello there are 2 big capacitor behind the metal heatsink see if one has swelled up if so change them both then check the output chip to see if there are any dry joints then when you've check all and still the same then you may have to change the output transistor g ood luck
shaun
Oct 01, 2009 | Technics SA-AX7
I have a technics sa-ax7 receiver and have sudenly lost sound on the right hand speakers.can they still be repaired. What could be the problem. Thanks
1). Look for a blown fuse on back - or inside. I had this similar problem with a Technics SA 5060 (vintage) receiver, and there were 2 separate fuses for left and right channels. One may be blown.
2). Try switching speakers (physically switch the left and right input plugs in their jacks - or wires if no jacks. If the left speaker doesn't work now, there is an issue with the speaker that has no sound. Run an ohm meter on these speakers as well to check them. There should be 8 ohms approximately. If no reading, then your apeaker is probably blown. If you can see a short on ohm meter 0 ohms) then you have a short circuit in your speaker.
Fred
Sep 21, 2009 | Technics SA-AX7
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
SAAX7 Technics stereo receiver stops broadcasting after 20-30 min
Ron- The fan does not turn on when the receiver is first powered on, it will run when the amplifiers begin to run HOT, they are kinda controlled by a thermo switch, if the fan does not turn on usually the receiver will shut down and display a OVERLOAD message in the display panel. My advise is to keep the unit well ventailated with plenty of breathing space around the top vent closure, this will allow air flow when loud volume output is used. Also use the rated ohm speakers with the SA-AX7,
Jan 25, 2009 | Technics Audio Players & Recorders
SA-AX7
its the orange input on the back of the amp left side of it from the fan says coaxial either above the input or below im not 100% if that will work for you i would suggest you use rca cable.
Dec 20, 2007 | Technics SA-AX730 Receiver
327 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
