Question about Intertherm Heating & Cooling
When I turn on my furance or ac the blower is always on even though the fan is set to auto. When it is on heat it never gives off any hot air, so it never warms up the house. I had someone look at it and he got the ignitor to glow, but could not get any gas to the unit. He was not knowledgeable of intertherm furnaces. He told me I needed a new gas valve. I read that this furnace has dual gas shut offs. Could that be the problem? If so how do I correct it?
    Genius:
  • 1,015 Answers
If this is a mobile home furnace they usually have a two stage gas valve. Generally they just have a delay in opening fully and are convertable from L.P to natural gas or vice versa. It is a possibilty that the gas valve is bad. If so it will have to be replaced. First I would have someone check your thermostat to see if that is what is causeing the blower to run . does the burner ever light? I wouldsuggest that you hire a service tech. who is knowledgable on intertherm furnaces. I don't recommend anyone who is not trained to change gas valves,because of safty concerns. I hope this helps you some. Thanks
Posted on Nov 13, 2010
  • corneliust Nov 14, 2010
    I do have a mobile home. The furnace never lights, even though the ignitor coil has glown at times. There are no technicians in this area that are knowledgeable in working with the intertherm furnaces.
  • Jack Spooner Nov 14, 2010
    Ok what I would try is to use a volt meter and check for voltage to gas valve. First turn thermostat to call for heat and put one probe from meter to terminal on gas valve marked th and the other to tr. You should read about 24 volts A.C. I would think that if ignitor is glowing then you probably have voltage to gas valve.If you do then I would take information from gas valve rating plate. It should tell you manufactures name,model,number and possibly gas type. Try to locate a exact match if you can, there are several ways to make other valves work but I would not recommend this. If you can find the right valve then turn off power and gas to unit. Usually it is easier to remove gas valve and burner at the same time. Remove screws holding covers around gas and pilot lines,sometimes there is a screw that holds burnere in place but usually it just slids in a slot in burner compartment. There should be a union on gas line to remove it from gas valve.dissconnect wires from gas valve being sure to mark them for proper hookup on reinstallation. Remove gas valve and burner assemble from furnace. Also dissconnect wireing for igniter. Removegas line to burner from outlet side of gas valve, and any pipe nipples or fitting to inlet side. To install new gas valve reverse sequence. .I hope you can get the right gas valve as this will make it much easier. On most new gas valves they will have a 3/4 x 1/2 inch pipe bushing if so use teflon tape or pipe joint compound on all threads and install. If you have to sub. a universal valve they may also have multiple Outlets so plug what you don't need. Finish installation,hook up wiring,turn on gas and check for leaks on all gas fittings,you can use dishsoap on threads if you suspect leaks if there is aleak soap will bubble ,fix leak befofe proceding. Finish and check everything before trying to turn furnace back on.I hope this helps. If I can do anything more let me know. Thanks
When air conditioner turns off out doors I can still hear it running in the attic.
Are you sure you are hearing the air conditioner running, or maybe just the blower? The blower may continue to run to further dry the evaporator core and reduce the chances of mold and mildew formation.
-Rod
Jun 03, 2017 | Heating & Cooling
My blower motor wont turn off in my furnance?
check the fan setting on your thermostat. On means always on, auto/int means only comes on during heating/cooling. if the thermostat is set to auto / int and the fan keeps running? you may have a bad fan relay switch. It may be integral on the primary control board of your unit.
Sep 04, 2014 | Heating & Cooling
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
I have an old RUUD central AC unit that started blowing hot air. I set the thermostat to off and set the temp gage higher than air temp to turn the unit off and save money, but inside blower unit runs...
Hello
Okay did you check your thermostat to see if you have the fan switch on auto? The switch must be on auto or the fan will continue to run. If the thermostat fan switch is on auto then there is a malfunction in the thermostat probably. You can go to your forced air unit and on unplug the unit. That way it will not turn on at all, because the forced air unit is controlled by the thermostat. Hope this helps.
Jul 26, 2009 | Heating & Cooling
FAN MOTOR CONTINUES RUNNING AFTER HEATING CYCLE IS COMPLETED BLOW
Check the thermostat. Make sure it is set for AUTO fan not ON fan. If that is OK replace the fan relay.
Apr 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Mar 28, 2009 | Carrier Heating & Cooling
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
Just a little question, guys!
The blower has absolutely nothing to do with outdoor air. Having the T-Stat set to auto lets the blower come on only when the A/C-heat comes on. With the switch in the ON position the blower simply runs all of the time. Depending on your living space (high ceilings, multi-level) having the blower on constantly while costing a small amount to run can actually save some money and make you more comfortable in the summer. However most people will leave it in auto in the winter so they don't feel as if they have a draft from the air movement as the blower is in high speed in fan on position and cool modes and low speed in heat mode. Many furnaces today are equipped with a setting that allows the blower to run constantly at a lower speed or simply run for a min. or two after the A/C=Heat have turned off.
Jan 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
In AUTO; blower won't come on when i turn heater/AC on.
most likely the heating speed relay on your furnaces IFC board has failed.Unfortunately the entire IFC must be replaced to repair this. you are in need of a professional service tech. The same control handles the blower fan, ignition system and safeties. Not a do-it-yourself repair as wires in the wrong place could cost you a house.
Dec 18, 2008 | Goodman CKL24AR24 Air Conditioner
Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Oct 24, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
202 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
