Question about GE Microwave Ovens
Microwave runs less tha 1 miute even when I reset time , clock,etc.
  • june parks Nov 15, 2010
    fixed it with the solution mentioned. Thanks
  • GE Master
  • 8,220 Answers
The microwave shutting down and reseting is a thermal cavity fuse mounted on the magnetron most likely.Your cavity TCO may be shutting down the microwave simply because the vent in the rear is blocked causing the magnetron to overheat. This is especially true if your microwave mounts above the stove. Clean up the vent on the back side of the microwave using some mean green or 409.
Here is a service manual, the TCO feature is explained on page 10.
I have a marvelous video I found on you tube and more HERE
Posted on Nov 12, 2010
Display image cannot be deleted and seems to be part of a time-set procedure?
If you wish to get some details about microwave oven repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | In Microwave Ovens
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot control Microwave, no action when clearing, setting, etc
This sounds like a door switch or key pad problem. If you haven't already tried this..... unplug the unit from the wall for atleast 1 hour and plug it back in. See if this helps.
Sep 11, 2009 | Microwave Ovens
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Jan 09, 2009 | Microwave Ovens
Resetting clcok on Microwave Oven..
I have a Magic Chef microwave oven, The model # is MCD1311ST.
After I reset the clock when daylight savings time ended, it displays 1:00 PM as 13:00, 2:00 PM as 14:00, etc. How do I get it back on a 12/12 cycle instead?
Warren.
Nov 08, 2008 | Magic Chef Microwave Ovens
Microwave resets when started
Could you explain what you mean by "resets similar to power cycle after 2 seconds of running"? Do the characters on the display get garbled, or is it like someone just unplugged the oven and plugged it back in? GE had a rash of "underperforming" magnetrons on several models. They would sometimes end up with stirrer damage, bad diodes, waveguide damage, and/or interference which "scrambles the brains" of the unit and makes them reset like they had been unplugged. The usual fix is to replace the magnetron, stirrer and high-voltage diode as a kit, and they used to cover this, but may not any more. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. In that case, the oven would have to be replaced. To get the details and see if yours is affected, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Even if your exact unit is not on the list, you may have this problem. You can contact GE Customer Relations at 1-800-386-1215 and tell them your problem and they will put you in touch with a local authorized servicer. Feel free to post back if you need more info. I appreciate your thoughtful rating of my answer.
Oct 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
170 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
