Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
No apparent power to unit. breaker is not tripped.
  • 618 Answers
Check the connection for the power to the machine (under the front kick panel to the right) . If ok check the door switch(s)
Posted on Nov 12, 2010
Unit runs for hours then power goes away, breaker not tripped
Possibly a backed up drain, possibly loose/melted high voltage wires just not tripping breaker, possibly wrong size breaker
May 29, 2017 | Heating & Cooling
I have a Husqvarna extractor fans, the type with the motor on the roof. In seems to work fine on full power but not no the lower power settings. It also trips out when the light and extractor are on at...
The 'trip out' is where the unit draws more power than the breaker is rated for. Because it runs ok on full power (check they are running at full speed on this setting), the breaker is allowing enough power to reach the unit in this setting, so the breaker is fine. However when you switch on the light with the extractor it trips, at that point it is drawing too much power through the breaker at it trips to stop the device burning out. Check the connections to the unit are clean and dry and firmly made, if not power could leak away drawing more from the breaker. The next step is to measure how much power is being drawn by the unit in each mode, using an Ammeter in line with it. If you do not know how to do this (its dangerous if you get it wrong) ask an electrician to check the current draw in all modes.
Dec 19, 2013 | Garden
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
Driver's power seat does not work
Are you also having other things that do not have power, such as the radio or power mirrors, or the wireless door locks / security system? I owned a 1996 Oldsmobile product that had the same problem. I discovered that a circuit breaker in the fuse box was being overloaded. The same circuit breaker that operated the seats also operated the wireless remote. Apparently, the wireless remote receiver was getting "hung" and constantly drawing electricity and tripped the breaker. When the breaker tripped, my seats also quit working. Thus I quit using the wireless remote and the seats have worked fine ever since.
Dec 16, 2011 | 2003 Chevrolet Silverado 1500
No power to tstat
If you have no power to the cooler control, your breaker has tripped. Check it. Turn it off hard, and back on hard. If it trips again, you have a problem up top, with a motor, pump, that is pulling enough amps to trip breaker. This is all it can be on these units, no power from main breaker to unit control.
Shastalaker7
A/C, & Heating Contractor
Mar 29, 2011 | Mastercool 67471 Evaporative Cooler Air...
Check power connection to machine under front kick panel to the right.If ok check door switch(s)
Nov 12, 2010 | Frigidaire Dishwashers
Heat pump breaker tripped now no power to the unit at all
When AC unit trips the breaker it usually means one of four possiblities.
1) the AC unit is causing the breaker to trip, i.e. a shorted fan motor, compressor, or some other electrical component - in which case you will probably need to have a repairman look at it.
2) you've plugged the unit into a outlet that is connected to a breaker which is too small to handle the load the AC unit is putting on it.
3) a defective breaker (not likely but possible)
4) just a 'random' trip and if you reset the breaker it might work fine.
good luck!
May 03, 2010 | Haier Energy Star ESA3183 Air Conditioner
(electric 240v 50 gal.,3 yr old)breaker on unit(not elec service panel) trips every afternoon-not apparantly under load
there may be a short in the heating element causing it to trip, or the breaker itself need to be replaced.
Dec 03, 2009 | Reliance Water Heaters
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
74 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
