Question about Cycling
The front wheel on my new Trek Navigator 1.0 rubs slightly at one spot only on the brake. How can this be corrected?
  • 718 Answers
Your rim is most likely bent at that point you may be able to correct this with spoke wrench, if you don't no how to adjust spokes take it to a bike shop and they will get you on your way in no time at all
Posted on Nov 13, 2010
2004 jeep grand charokee grinding noise when
ok, think about mass that moves under the forces of braking, things like engines and gearboxes, have you checked all those mounts for integrity, have a look to see if anything has been rubbing, new shiney spots appearing that weren't there before.
Oct 17, 2014 | 2004 Jeep Grand Cherokee
What is the front wheel size of trek 3700 ?
Rotate your wheel so that the valve is in the 6 o'clock position, mark where it is on the ground and roll the wheel along the ground 1 complete revolution (until valve reaches the 6 o'clock position again), mark that and measure between the 2 marks.
Aug 15, 2014 | Trek Cycling
Pedal assembly for a trek navigator 100
This bike had a square-taper bottom bracket. What happens with this type is that the bolts holding them on become slightly loose over time. The crank arm begins to wobble and the "wollows" out the inner hole on the crank arm such that a new one will have to be purchased. They are about $15.
The only parts envolved are the cranl arm and the both that holds it in place.
Jun 07, 2014 | Trek Navigator 100
Need to adjust front brake pads
There is an adjuster where cable enters brake caliper
Also you could loosen mounting bolt. Realign and tighten.
Apr 09, 2014 | Trek 3700
The procedure for removing the rear wheel from my Trek Navigator 200 to repair a puncture or replace the inner tube. Regards Paul emson
Try any Search Engine for "removing the rear wheel " and "repair a puncture"
The internet has most answers immediately and some with video.
Aug 08, 2011 | Trek Navigator 200
Hearing a scraping noise about 15 mph , replaced front wheel bearing
The scraping noise could be a brake pad rubbing on a rotor, most likely caused by not getting the axle set in the right spot after replacing the wheel bearings, (assuming everything else was done correctly). Start by supporting bike with front wheel off the ground. Loosen the front axle nut. Loosen the clamp on the bottom of the right side lower leg. Insert a 7/16" drill bit or steel rod or drill bit, (whatever will fit through the hole without too much slop). Tighten axle nut to 50 to 55 ft lbs. Tighten clamp nuts. Spin the wheel and operate the hand brake a few times. Wheel should now be centered with the brake rotors running in the center of the brake pads. If not, you may have mixed up the spacers.
Nov 03, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
The front brake on our 2006 Suzuki C50 seems to be rubbing the front tire in one place. It's not enough to slow the tire, but when we put it on jack and turn front wheel, we can hear it rubbing. Is
disc/rotor is warped in one spot, doesn't sound extreme...if it's buggin' you have it turned at a motorcycle shop, otherwise just ride my friend, it's not dangerous....Tim
May 30, 2009 | 2005 Suzuki Boulevard C50
Cycling Logo
94 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
