Cannot restart washer after cycle was interupted. Intake and drain lights flashing.
  • 618 Answers
Need make and model but first unplug for 10 min. and try again.
Posted on Nov 12, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
I have a front loader HE washer. The lights are
Try unplugging the washer and see if the latch disengages. I'm also wondering if the cycle was interupted (power loss) and a restart is necessary.
Aug 02, 2009 | Washing Machines
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Cancel drain light continue to flash and dish washer will not make a sound
Hi sandsmi8,
I'm Harvey the Master Plumber.
You're telling me only: cancel drain light continue to flash and dish washer will not make a sound.
Based on this info alone you might be able to reset the d/w with power interuption. Try turning off the breaker for ten minutes. With some models this will reset the d/w computer. If that dosen't work you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Whirlpool Duet's interupted cycle won't restart
unplug, let sit for 2 min, replug and try to put into drain/spin cycle
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer interupted while running
Try pressing "end of cycle". Then restart your normal wash.
If helped pl rate me................................
Jan 23, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
