Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door remote won't open the garage door
Worked fine until today! When I press the remote button in my car the green light goes on ( on the remote and on the opener in the garage ) but nothing else happens. The wired opener button on garage wall works just fine .
  • 6 more comments
  • vfivpo Jul 14, 2008
    Our remotes just stopped working along with the keyless entry system. We're tried changing batteries and re-programming, and also checked to make sure the vacation lockout feature was not on, and nothing works. A neighbor suggested that a neighbor's new router might be causing the problem. ???
  • coachjaw Jul 19, 2008
    Same problem here. Has worked fine for 5 years and now both remotes do not work but the wall button does. The lock out is off! When I push the remote the LED light on the openner flashes 3 times so it gets something.
  • Anonymous Jan 11, 2009
    I have the same problem with the remote but mine is a Wayne Dalton......I can't find a button with a "padlock" on the wall.
  • brenza Jan 18, 2009
    Seems I have the same problem with the garage door remote not working. Plus my neighbour next door has the same problem.. Happened on the same day. Though I think it is our wireless router that is causing the problem. On the day it happened, the night before we replace our anenna on our router.
    We have changed the channel on our router to see if it fixes the problem. Haven't tried it, but I'm hoping it works..
  • griccobo Mar 05, 2009
    My neighbor must have hit the lockout button after I left for work and left my door open. Now I can't get in and there is no other door. The manual key release also will not work Is there any solution now/ griccobo@msn.com
  • vito d May 05, 2009
    After changed out batteries, neither remote works. The wired station works fine.
  • Anonymous Mar 27, 2014
    can you give instructions on how to programme a orca garage ace remote to open a car shed door
    Garage door not working at all when i press remote
    Guru:
  • 1,342 Answers
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
I have a problem with the garage door opener. The wall control operates ok. First i couldn't close the door with remote but could close. But recently i couldn't open and close and wall control still works ok. But i noticed the right side senser light is not blinking it's off. Is the problem with the senser?
Posted on Jan 20, 2010
My solution for this problem was to reset the remotes. I have a 2004 Sears opener. To reset the remotes, a reset button on the motor itself (my model's reset button is located underneath the light cover, which swings down for access, and is the same button used to reset the code), is pushed and then the remote button is held until the lights on the motor blink (in my case it took ~2 seconds).
Posted on Jul 24, 2009
    New Friend:
Check out George B's solution. It worked for me, and saved me a lot of useless trouble! The little 'lock' button on the wired connection. Should turn off the blinking LED light that indicates remotes won't work...for vacation safety.
Posted on Jan 01, 2013
The internet has all sorts of features, some not so good, most really great.  Count this among the latter.  I'm not good at keeping track of a bunch of owners manuals, so I would have let this green light blinking phenomenon/no remote from car problem go for a long time.  One google search away, and some helpful person has solved my "problem" almost quicker than it took to search for the answer! Thanks for helping with a solution.  That's building community.  Good karma!  Thanks so much.
Posted on Oct 06, 2008
Coincidentally, as soon as the neighbor with the new router moved, the garage door openers started working again. Just before the problem started, geek squad was working on their router. Apparently, they changed a channel that affected all of our garage door openers (within 4-5 houses each way).
2 Suggested Answers
  • 905 Answers
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
I have the Liftmaster Chamberlain Professional Formula I model 102.1499A and for some reason, the learn button will not sync with the homelink on two of my cars. Is there a way to reset the learn button? ...
Here is the information I have for homelink.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do i program my car to open the door? i have built into my new car. everytime i try to program it, it will not work. what am i doing wrong?
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
If this doesn't work your car and homelink may not be compatible.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Homelink wireless remote is stuck on fast flashing red light. I can't seem to clear my remote to program any of the buttons to my garage door opener. This is the second one I purchased, I had no...
Try this.
HOMELINK PROGRAMMING
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
15,365 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
