Question about Dmm Vision Fitness T9500 Treadmill
How to fix and E6 error on my Vision Fitness treadmill 9600
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
What does error code R5232 Failed mean on Vision Fitness T9600HRT treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 04, 2016 | Vision Fitness Exercise & Fitness
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
Jan 10, 2016 | Vision Fitness T9200 Treadmill
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
Jan 20, 2013 | LifeSpan Fitness TR200 FoldNStor Compact...
Using treadmill stopped and display shows E6 I can not start it again
E6 is error code. You need to go to Vision Fitness website to request the answer to your question. It probably has something to do with the timer circuit.
Dec 26, 2012 | Computers & Internet
M tf40 vision fitness treadmill wont change incline or speed only just got today
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
see the diagram attached.
God bless you
Dec 18, 2012 | Vision Fitness TF40 Classic Folding...
VISUAL FITNESS t97005 e6 ERROR CODE
LUBE THE deck belt, this happen because lack of maintenance, do ti
2( lube the rollers bearing too
3( test the input voltage motor, if there are the motor need repair
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 24, 2012 | Dmm Vision Fitness T9500 Treadmill
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
Dmm Vision Fitness T9500 Treadmill Logo
462 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
