Question about Gateway FPD1760 17" LCD Monitor
Problem with FPD1760 Gateway monitor
The other day my monitor went blank, I reached to the back to check on the cord and itcame back on. When bringing my hand back tothe key board,I touched the menu buttons on the right hand side of the monitor, and this caused the screen to move about 4 inches to the right, and the picture became too bright for me to read or see anything. Up to now the left hand side of the screen is black and the screen moved tothe right and I still cant read or see mostthings clearly due to thebrightness.
Gateway said I had to pay about $200 for them to listen to my problem as the computer had just come out of warranty. (1 year old) Someone please help. I can't afford tobuy another monitor right now.
Thanks
    Sergeant:
  • 284 Answers
Sounds like the LCD inverter gone bad.
you might get lucky in finding one on EBAY.
yeah gateway sucks on customer service.
Posted on Jun 18, 2008
Vga cord for gateway fpd 1760
Search for it online (if still available).
Jun 06, 2014 | Gateway FPD1760 17" LCD Monitor
Gateway fpd1760 tft lcd color monitor i not warking
- isolate the problem first by checking all the cables for any bent pins and loose wire/ connections - unplug the lcd monitor and try to get a spare computer to check if its your computer's video card or the lcd monitor - if lcd will give display using a different computer it only means there's something wrong in the computer's video card - if lcd will not give display using a different computer it only means lcd had gone bad and needs to be replaced.
thanks.
Jan 03, 2011 | Gateway FPD1760 Monitor
I want to put my laptop and connect it with Gateway monitor. What type of plugs do I need?
Spec of the monitor http://www.dealtime.com/xPF-Gateway-Gateway-Monitor-FPD1760
It will need the VGA cable (3-row/15-pin D-SUB), you need to look at your laptop monitor port to see what you have for the output.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
And you will need to set the laptop video signal to be at the native resolution of this monitor, which is 1280 x 1024 @60Hz.
Sep 10, 2010 | Gateway FPD1760 17" LCD Monitor
Gateway fpd1760 lcd monitor no power at all the blue led clicks on for 5 seconds the screen flashes for a milla second then nothing
check if the signal cable has been plugged in properly at the back of the screen and at the back of the computer.
if you have another computer or laptop,.check if the screen works fine with it.as this could even be a boot up problem with the computer
Feb 04, 2010 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1760 the red in the rgb is suddenly gone
Your graphics card is not working propertly buy a new one.
Mar 15, 2009 | Gateway FPD1760 17" LCD Monitor
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
Syncmaster Screen went blank on my Dad
check and see if there is any buttons on the side of the monitor or in the front area. also, check wiring plug connections.
Jun 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor won't turn on.
Does the cord plug directly from the wall into the monitor, or is there a power "brick" adapter between?
If there's a "brick" listen to see if the hissing is coming from the monitor itself or the brick. If the hissing is coming from the brick you may just need a new power adapter.
If there's no brick or the hissing is coming from the monitor, the monitor probably needs repair. With the price of LCD monitors these days compared to the price of labor, you're probably better off getting a new LCD monitor. Just make sure you take your old one to a proper E-Waste facility so it doesn't pollute the environment.
Apr 05, 2008 | Gateway FPD1760 17" LCD Monitor
My Gateway FPD1760 Won't turn on.
Inverter or Inverter boards Blown.
Hope this helps.
Mike @ compurepair.
Feb 23, 2008 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1760 17" LCD Monitor Logo
210 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
