Question about Pride Mobility Products Jazzy Select 14
How do I find and replace the 7.5 Amp battery charger fuse?
  • 280 Answers
The 7.5 Amp ATO fuse is located in line with a rubber cap on it under the rear electronics cover. It is a well kept secret, well hidden, and you have to know its there. The rear electronics cover has an AC receptacle, meter, circuit breaker reset button, and main hand control connector on it. Remove the cover and look for the in-line fuse. It is a black rubber fuse holder with a rubber cover. It is connected with one wire to the harness connected to the charger and the other wire from it goes to the charging meter (red and green with moving pointer). It is probably easiest to find the fuse holder by starting at the meter and tracing the wire back to the fuse holder. Pull off the rubber cap and insert a new automotive style 7.5 amp fuse. You can tell if the old fuse is burnt out by holding it up to the light. If the wire inside is burnt open, the fuse is bad. Be careful when putting everything back together that you don't pinch or disconnect any wiring. Hope this helps.
Posted on Nov 13, 2010
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
The charger blows the 3.15a/250v slow blow fuse the second I plug it in... what can I do to get the charger working again?
check that you have the red lead of the charger on the positive terminal of the battery and the black lead on the negative terminal of the battery. Next check the voltage to be charged is selected correctly 6 volt or 12 volt. next check the rating of the fuse used as 3.15 amp may be too low for the charger. I would not go greater than 5 amp at best. Lastly have the charger checked by an accredited electrician for internal shorts.
Jan 17, 2015 | Cars & Trucks
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
10 amp draw draining battery overnight on 99 tahoe
I have done this before, put about a 10 amp charger on the battery. Pull the courtesy light fuse first. Look at the battery charger, it is probably charging several amps, pull one fuse at a time. When the charging amps drops down you found the fuse the controls the problem. I had a car several years ago that someone pulled the seat belt all the way out, somehow it was pulling a load and draining the battery overnight.
Jan 05, 2012 | 1999 Chevrolet Tahoe
Charger system on 2002 ranger
try replacing your voltage regulator
Nov 18, 2011 | 2002 Ford Ranger Regular Cab
When I plug the battery in for charging, the charge light does not come on. only the power light on the charger
There are several solutions to this problem which I have seen twice in my technical career.
You indicated that the power light on the charger comes on which indicates it is plugged into a working AC wall outlet. Check to make sure the power switch of the charger is turned on. Make sure that the round charger plug is plugged all the way into the battery charger receptacle on the battery box.
Next, check the on-board fuse AND the circuit breaker. I have had this little 5 Amp automotive style fuse burn out on several go go's and the charger does not work. Pull back the cover over the charger port and look for the fuse in its center slot. With a good set of fingernails it can be pulled straight out and inspected. Use fine needle nose pliers if necessary. I am assuming the go go runs and the push-button for the 15 Amp circuit breaker is pushed in. If it is out and the go go is not running reset the breaker by pushing the white button in. There is a clear rubber boot over the button. In my experience, the 5 amp auto fuse is your most likely problem. By holding it up to the light you can see if the fuse wire inside is burnt causing an open circuit. Most auto and hardware stores have this fuse in stock. Bring the old one to the store for comparison. It is a 5 Amp ATO fuse.
The question my clients often ask is what caused the charger circuit to overheat and the fuse to blow? The simple answer is that the two 12 Amp hour batteries in the go go are probably old and weak. This causes the charger to work too hard and the circuit to overheat and the fuse to blow. These small batteries have a short life span of between 6 months and 1 year depending on type. I recommend the AGM (advanced glass mat) batteries for longevity. Also make sure the charger being used on the chair is the 2 Amp small charger that came with the chair (There is a label on the charger to verify this). A larger charger will burn the batteries(shortening their life) and burn out the 5 Amp on-board fuse. Hope this helps.
Oct 31, 2010 | Pride Mobility Products Go Go Ultra X 3...
Batteries not charging - just replaced with new -amp meter dosent move while plugged in. Old batteries were dead and owners manual says charger will cease to work when batteries die and to contact pride...
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
May 07, 2009 | Jet 3 Ultra Power Chair
What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Mar 07, 2009 | Ryobi Multi-Volt Battery Charger
Charger for 12 volts 7 amp battery smf
you need to go to a **** smith store and bye a kit to do this cheers peter
Apr 18, 2008 | Ryobi Multi-Volt Battery Charger
Pride Mobility Products Jazzy Select 14 Logo
534 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
