Question about Fisher and Paykel GWL11 Top Load Washer
Cold water isn't working it is contected the correct way. This just stated in the last day or so while doing a load. The board starts beeping that there ins't any cold water.
  • 3 more comments
  • Kevin Buckne Nov 12, 2010
    No bad water I live a a Miltary base great water took the hose off made sure that the hose is working good to go. What's nesx?
    No blockage water line is good to go. I live on a miltary base so the water is city.
    This just started to happing the other day for no reason at all.
  • Kevin Buckne Nov 13, 2010
    Are you still working ??
    Are you still working??
    President:
  • 1,554 Answers
It's either the cold water valve is not working at all, there's no power getting to it from the Motor Controller Module, or the inlet chamber thermistor is faulty. Check for 24VDC at the cold water valve solenoid terminals during the time that the valve should activate. The valve is not working and must be replaced if there's power getting to it. Check the connections if there's no power and if the connections are good, the Motor Controller Module is faulty. If water is coming in but not detected, consider replacing the inlet chamber thermistor.
Posted on Nov 13, 2010
    President:
  • 2,468 Answers
Remove the watehose and check for a blocked water hose screen in the water inlet,if you have well water from a very rocky terrain it can pick up this sediment thru the jet pump if in a rural area or even if its in a local municipality with hard water sediment
Posted on Nov 12, 2010
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer HE3t won't turn on but is making beeping error sound when pressing power button. Is there a reset button to press or common problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My front loader is not working whirlpool
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite beeps all the time
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
MY kenmore elite has no power only beeps I see 2 wires to one board broken tryed to reinstall still no power. Can anyone help with this piece of shi_ has had 7 service calls
Jun 17, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Washing machine not starting
Jan 03, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
