Question about Samsung (SC-152) Internal 52x CD-ROM Drive
My CD drive stays open and will not close unless I force it. I noticed it stopped working when I inserted a cd to view some photos from 2005. It was making an ugly noise. A couple days later I noticed this problem that is no longer working. The tray stays open and will not close unless I force it. Do I need to have it repaired at the computer place?
  • Samsung Master
  • 27,725 Answers
Make sure that its getting enough power
test all the leads that are attached to the drive make sure they have secure connections and are not faulty or just replace them including electrical extensions
or control panel administrive tools computer management device manager scroll to cd\dvd rom drives select+ to expand right click on your drive select properties then you can troublehoot it
hope this helps
Posted on Nov 12, 2010
    Scholar:
  • 54 Answers
Replace the drive and install the drivers for it. Computer tech, yes.
Dawn
SouthportPC
My cd drive on my x box 360 wont open
Most likely the disk drive has a loose axle in it. when these are loose they can jam the ejection of the drive which stops it from working as well. There is a switch inside of the xbox that flips when the disk is inserted all the way that tells the xbox there is a disk in it. Forcing it open will only damage the drive more. so its better to have it shipped or fix. If you have a warranty on it, let the company handle the situation, for if you damage it more they will less likely want to fix the problem you made worse.
Apr 07, 2013 | Microsoft (X-Box) P5F-00001 Xbox 360...
Tip
CD Insert Without pushing a button!
This will not work with a Laptop drive unless it is the slot loading type.
We already have 'Eject' when we right click the CD/DVD drive from (My Computer), which ejects the drive tray. But to insert the tray inside,we have to manually push the insert button on CD/DVD drive.
Another way most PC owners insert that CD tray is by pushing the tray itself. I'm sure nobody mentioned this when you got that PC, but that push to insert feature (Also called the bump feed) is not really safe to use over time. If you happen to say, push too hard because you are in a hurry, the gear which pulls your CD tray in can skip a tooth, making that CD or DVD open and close all by itself, or even worse, making it stay locked tight forever.
Here is a trick that allows you to insert the drive tray without actually touching that button. Simply by putting the 'Insert' sub-context(as shown in above figure) menu on the CD/DVD drives Context menu. For this to happen, we need to use a dll file from our windowssystem32 folder.
First of all, download this file CDEject.zip and extract it. There will be two files CDeject.dll and CDeject.reg. Now follow the step by step procedures.
1. CDeject.dll -> copy this file to X:windowssystem32 folder (here X is your corresponding drive letter, usually it's drive C:)
2. CDeject.reg -> execute it. It shows a warning message, accept that and click OK.
Now try right clicking your CD or DVD drive and click eject, then right click again and choose insert.
Amazingly cool isn't it?
So far I haven't found a way to make the CD hop in the tray all by itself, but I am still hopeful.
And you thought you couldn't program!
Have fun with that!
Please Vote for this Tip if you found it helpful.
Bob S.
on Apr 02, 2010 | Computers & Internet
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
CD drive stays open
Dirty lense? Best to get a new one. It maybe the motor aswell. CD drives are normally about £10
Jul 14, 2009 | Samsung (SC-152) Internal 52x CD-ROM Drive
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
DVD DRIVE OF MY HP LAPTOP
what of a laptop is it this??????
Sep 21, 2007 | Toshiba SD C2502 Internal DVD Drive
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Cdr tray/door won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Aug 09, 2007 | Philips CDR785 3-Disc CD Recorder
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Samsung (SC-152) Internal 52x CD-ROM Drive Logo
164 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
