Question about HP LaserJet 3330 All-In-One Printer
Need little guidence
I been going throught same problem, and i was wondering if you can give me some guide as how i can go about replacing it the scanner.
    Problem Solver:
  • 14 Answers
Remove 2 screws from the left scanner cover, disconnect the flat ribbon cable from the formatter (main board). There are 2 silver self tapping screws in the rear and 1 each on the side of the unit that need removed. Slide the scanner section forward slightly and lift off.
Posted on Jun 19, 2008
I have Xerox 8550 coming up with a jam when the printer starts up. The C3T error code is given. Today I opened it up and following the instructions from the Service Manual I did the homing procedures on...
Two things normally cause that. Look in the area inside the top cover where there are 2 green guides that flip up so you can clear a jam off the drum. See if the clear mylar guide it bent or cut causing the jam.
If that is ok then more than likely you have a process drive timing problem. That is the drive gear assembly on the right side of the machine.
You can try removing it and retiming it by inerting pins throught the timing holes.
I suspect a process Drive timing problem
Mar 01, 2010 | Xerox Phaser 8500/DN Printer
Hi, i was wondering how to get my printer back online I have a hp deskjet f340
I would like a little more information but lets give this a try. Go to control panel and click on computer and faxes. Right click on printer you are useing and click use printer online. Hope this helps if not get back to me... Darren
Oct 10, 2009 | HP Deskjet F340 All-In-One Printer
Reload of software on Fiery 405 canon
i have canon ir 405 copier. i want to reload fiery software because my machine is not giving priting & is erroe E677 pl tell me about.
Jul 06, 2009 | Canon Office Equipment & Supplies
Does not pick up paper from the tray
How much paper gone throught the printer since it is new?
usually the pickup roller is good for 10,000-15,000 sheets.(20x500 sheet pack). if the printer went throught that much paper, then the pick up roller need to be replaced.
if not, make sure there nothing stucked on the pickup roller, and the roller is not shining (it need to be soft and rough).
Apr 18, 2009 | Dell 1700 Laser Printer
Replace toner
Please click here and the installation guide to install the toner cartridges ..
Good luck..
Nov 11, 2008 | Lexmark C912 Led Printer
Fiery patches
hi better u try to xerox.com/drivers..
Oct 01, 2008 | Xerox DocuColor 12 Printer
Printer cartridge
Go to:
www.lexmark.com. There you can order the cartridge you need and you can also download to look at the guide on how to set up the printer under publications in support.
I suggest you take a look at the guide and see where the cartridge goes and then if the cartridge is not there, order what you need.
The guide is in pdf format so you need to have acrobat reader installed in order to read it. That is a free download at www.adobe.com/acrobat.
Aug 06, 2008 | Lexmark X2350 All-In-One InkJet Printer
Paper wont feed
Printer needs a service: Paper feed rollers are dirty and can't pick the paper up
Apr 28, 2008 | HP PSC 1510 All-In-One InkJet Printer
How to refill printer cartridge
Hello, it is always a bit offputting the first time you go to do it, but once you have you will not look back, you save so much money. I only go throught 3-4 cartridges a year now i refill and amazingly i get 7-8 refills each cartridge on my lexmark x1185
Please describe your cartridge, does it have alittle plastic cover over top?
Feb 16, 2008 | Brother MFC-440CN InkJet Printer
HP LaserJet 3330 All-In-One Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
