Question about Sharp LC52D65U 52 in. LCD TV
We have a green line going vertically up and down the far right side of the screen. Is there a way to correct this?
  • Sharp Master
  • 736 Answers
If you have a motorola cable box it is coming from it. Turn off the cable box and press the menu button on the front of it. yes I did say turn off the cable box. Then go down to the color system menu subcategory and change it. If it is set for 4:1:1 change it to Ypbpr or vice versa.
Posted on Nov 12, 2010
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
I have green arched =lines r=going through my screen How do I fix this?
If the lines are slanted up from left to right and spaced several inches apart, you are seeing the vertical retrace line. In that case, you may want to turn down the screen voltage on the green CRT. The instructions for making this adjustment are given in the service manual.
It should take just a small tweak to hide the retrace line. If adjusting the screen voltage won't do the job, check for a leaky or improperly biased CRT driver transistor, then compare the video waveforms with one of the other CRTs to make sure the voltage at the vertical blanking interval is correct.
In the worst case, there is a problem with the CRT. This is generally accompanied by occasional arcing (bright green flash or the set shuts down with an error code flashing on the power light).
Dec 05, 2010 | Sony KP-51WS500 51" Rear Projection...
Thin vertical line running down the right side of the screen
See if you can use the remote to shift the picture to the right. It depend on how far the line is to the right. If that don't fix the problem the set will need to have internal boards replaced. It may be the logic board and the logic buffers...
Oct 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Sharp LC52D65U 52 in. LCD TV Logo
210 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
