Question about Blaupunkt VP 4 Car DVD Player
My car has a Blaupunkt rear seat DVD player system- the DVD/mp3 player is mounted under the front passenger seat, and there are two DVD screens - one in the headrest of each of the front seats. I do not know the model number. One of the DVD screens is broken. I would like to replace it. Where can I get a new screen? The screen measures 6 1/2 inches wide and 4 inches tall. It's about 1 inch deep. I have taken it out of the headrest and can see that it has a plug to plug into the system, so it would seem that replacement is just an issue of getting a correct screen and plugging it into the cable connection. Can you assist me? I have photos I could send but do not have model number.... THANKS!
Eagleeyes
  • 199 Answers
SOURCE: Blaupunkt 7-inch Monitor reads no disc
if it is the laser then its a new unit as the lasers are not supplied as a spare part. you can get the whole mech. but its cheeper to get a new unit.
Mark
Blue ICE
www.blueice-electronics.co.uk
Posted on Feb 24, 2008
  • 5 Answers
SOURCE: No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
Posted on Feb 10, 2010
schast
  • 56 Answers
SOURCE: Need rear panel drawing or install instr for Heidelberg CD51
Crutchfield has the manual available for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/023/023HDLCD51.PDF
I saw a picture in the manual showing where the various connectors plug in. You should be able to tell from there what the orientation should be. It was page 29 of the PDF.
Posted on Feb 16, 2010
Testimonial: "Thanks very much for the information. This is a more complete version of the manual than the one that I have, and it contains the information I need. "
drsinister69
  • 2317 Answers
SOURCE: i got a pair of Blauplunkt headrest monitor
You need a DIN cable.
Posted on May 09, 2010
Testimonial: "very helpful!! thanks a lot!!"
  • 4944 Answers
SOURCE: Need the code for Blaupunkt IDC A09
Ask here for free advice and code
www.ukbookshelf.co.uk
Posted on Jun 28, 2010
Is driver airbag still functional when passenger airbag light is on in a 2010 Chevy malibu?
Hello Collette,
(Owner Manual Page 2-68)
The passenger sensing system turns off the right front
passenger frontal airbag and seat-mounted side
impact airbag under certain conditions. The driver
airbags and the roof-rail airbags are not affected by the
passenger sensing system.
The passenger sensing system works with sensors that
are part of the right front passenger seat. The sensors
are designed to detect the presence of a properly-seated
occupant and determine if the right front passenger
frontal airbag and seat-mounted side impact airbag
should be enabled (may inflate) or not.
I'm not sure if a purse or other light weight objects would activate the passenger airbag but if your display is showing random passenger activation it would be best to have a qualified dealer check into it...better safe than sorry.
http://www.gm.ca/media/owners/manuals/2010_Chevrolet_Malibu_Manual_en_CA.pdf
Jul 19, 2016 | 2010 Chevrolet Malibu
Handlebars are bent
Instructions
YZF600R (1994 - 2007)
Insert the ignition key into the seat lock, located on the left side of the tail fairing above the left passenger foot peg. Twist the key clockwise to release the seat lock mechanism.
Grasp the rear portion of the seat and lift it off of the motorcycle's subframe. Pull the front of the seat away from the gas tank until the tab under the front of the seat is free of the subframe.
Hold the seat over the subframe to reinstall it. Hook the seat's tab under the cross-member below the base of the gas tank.
Push the seat forward slightly, then lower the rear of the seat onto the motorcycle's subframe.
5
Push down on the rear of the seat until the seat lock mechanism clicks into place. Remove the ignition key from the seat lock.
YZF-R6 (1998 - Present)
6
Insert the ignition key into the seat lock on the left side of the tail fairing. 2006 and newer R6 models place the seat lock under the tail fairing, near the left rear foot peg. Twist the key clockwise to release the seat lock mechanism.
7
Grasp the rear of the passenger seat and lift it up slightly. Pull the seat toward the rear of the motorcycle until the hooks under the front of the seat are free of the tabs built into the subframe under the tail fairing.
8
Pull the rear corners of the rider's seat up to reveal both mounting bolts. Unscrew the bolts with a 5 mm Allen wrench. Lift the rear of the seat up, then pull it away from the gas tank until the tabs under the front of the seat are free of the cross-member below the base of the gas tank.
9
Slide the rider's seat tabs under the frame cross-member to reinstall the seat. Lower the back of the seat onto the subframe, then screw the mounting bolts into place with a 5 mm Allen wrench.
10
Hook the front of the passenger seat onto the tabs built into the subframe under the tail fairing. Lower the seat onto the fairing and press down until the seat lock mechanism clicks into place. Remove the ignition key from the seat lock.
Jan 15, 2013 | Yamaha XT 125 X Motorcycles
Replace a rear evaporated core from 2002 dodge grand caravan
Remove the rear weather stopping. Remove the two passenger side rear seat belt mounting bolts. Remove the upper and lower rear trim covers. Remove the passenger rear most trim panel. Remove the passenger trim panel Justin from of that. Remove the lines from the EVAP core from under the vehicle. Remove the several screws and nuts that hold the rear HVAC housing in place. Carefully swing the HVAC housing away from the side of the vehicle keeping in mind you will need to unplug a couple connectors and use caution not to pull out the heater hoses when doing this. Disassembly the housing and swap out the EVAP core. The rear lines disconnect towards the front of the vehicle about right under the passenger front seat. They will be held to the body with half a dozen fastners.
Aug 07, 2012 | Cars & Trucks
What is the oxygen sensor do on a chevolete S10 pickup?
Two locatios there:
* Under vehicle, passenger side, below seating area, mounted in exhaust pipe in rear of catalytic converter
Under vehicle, passenger side, below seating area, front of catalytic converter, mounted in exhaust pipe
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
May 04, 2012 | Chevrolet S 10 Cars & Trucks
How I can take off Random play from bus blaupunkt dvd-player. It shows (Random) on left side on screen when I put DVD in and movie jumps every few minutes. Very bad to watch movies, cause have to find...
There should be a DVD Repeat modes or "Repeat/Repeat Modes" button on your remote. Press that until it's back to "ALL" and it should play things properly again for you.
Aug 27, 2011 | Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car...
Keycode for Visteon Rear HeadrestDVD player 2007 Ford S-Max car.
Hi, we have a solution for you.
www.cat-essex.com
Jul 09, 2010 | Car Audio & Video
I need the location of the fuel filter 3.8 litre
right side just aft of the front right tire underneath
Nov 21, 2009 | 1992 Buick LeSabre
I NEEDED THE 2001DODEGE CARAVAN SPECIFICATION
2001 Dodge Caravan Performance Features -3,301 cc 3.3 liters 6 V engine with 93 mm bore, 81 mm stroke, 9.3 compression ratio, overhead valve and two valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 9.8
-Multi-point injection fuel system
-Main 76 liter unleaded fuel tank
-Power: SAE and 134 kW , 180 HP @ 5,000 rpm; 210 ft lb , 285 Nm @ 4,000 rpm
2001 Dodge Caravan Handling & Driving Features -ABS
-Two disc brakes including two ventilated discs
-Spacesaver steel rim under body spare wheel
-Strut front suspension with stabilizer bar independent with coil springs , beam rear suspension with stabilizer bar rigid with leaf springs
2001 Dodge Caravan Exterior Features -Body side molding
-Front and rear body color bumpers
-Driver and passenger power heated black door mirrors
-External dimensions: overall length (mm): 4,803, overall width (mm): 1,996, overall height (mm): 1,750, wheelbase (mm): 2,878, front track (mm): 1,600, rear track (mm): 1,626 and curb to curb turning circle (mm): 11,460
-Complex surface lens halogen bulb headlights
-Double sliding minivan side door
-Remote control operation opening rear ¼ windows
-Metallic paint , gloss paint , pearl paint
-Fixed rear window
-Tinted glass on cabin, rear and side
-Weights: curb weight (kg) 1,842, gross trailer weight braked (kg) 907 and max legal load (kg) 772
-Windshield wipers with variable intermittent wipe
2001 Dodge Caravan Interior Features -Air conditioning with rear outlet
-Fixed mast antenna
-Manufacturer's own audio system
-Automatic drive indicator on dashboard
-Below seat storage under passenger seat
-Cargo capacity: all seats in place (liters): 433, all seats removed (liters): 4,154 and third row seats removed (liters): 1,291
-Clock
-Dashboard full console with open storage box
-Delayed/fade courtesy lights
-Cruise control
-Front seats, rear seats and 3rd row seats cup holders
-Door ajar warning
-Door pockets/bins for driver seat and passenger seat
-Floor covering: carpet in load area
-Driver and passenger front airbag
-Bucket seat
-3-point reel height adjustable front seat belts on driver seat and passenger seat
-Front seat center armrest
-Glove compartment
-Height adjustable two head restraints on front seats, rear seats and 3rd row seats
-Internal dimensions: front headroom (mm): 1,011, rear headroom (mm): 998, front hip room (mm): 1,440, rear hip room (mm): 1,722, front leg room (mm): 1,031, rear leg room (mm): 930, front shoulder room (mm): 1,588 and rear shoulder room (mm): 1,643
-Low fuel level warning
-Low washer fluid level warning
-Internal button power locks
-Power steering
-Front power windows with one one-touch
-Front reading lights
-3-point reel height adjustable rear seat belts on driver side and passenger side
-Bench one-piece two rear seats
-Rear view mirror
-Upgraded cloth/velour seat upholstery
-Seating: seven seats
-Six speakers
-Plastic steering wheel
-Tachometer
-3-point reel third row seat belts on driver side , 3-point reel third row seat belts on passenger side , lap static third row seat belts on center side
-Front facing bench removable one-piece third row seats with capacity three
-Driver and passenger vanity mirror
-Ventilation system with recirculation setting
Thanks.
Jun 18, 2009 | 2001 Dodge Caravan
Where is the DVD player for the sat nav system in a Freelander 2
look in the trunk,sometimes mounted on the upper inside
Nov 19, 2008 | 2007 Land Rover LR2
Blaupunkt VP 4 Car DVD Player Logo
50 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
