Question about Denon AVR-1508 Receiver
I have a Denon 1508. How do you change the volume on the rear speakers?
  • 600 Answers
First see if the connection of the speaker are connected in the right terminals, REAR speaker should be connected to REAR or ZONE 2 speakers(Surround Speakers).
Next is to check the settings on the units's " SPEAKER SETUP" menu, as seen here
Next would be the surround parameters, a wrong surround parameter or setting may lower volume on channels depending on where it is set to, or "shifted to" Please refer to this next image.
PICTURE2 In the above pictures, I have highlighted or "boxed" the necessary things you may want to check.
To furthermore guide you to set your unit's setting please download this manual,and make it a reference.
Posted on Nov 13, 2010
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
Similar situation as previously described with the Denon AVR-1508, but mine will shut off after about 10-12 minutes the first time around and then ~2 minutes after it is turned off and then back on. Unit...
Most new receivers have a fan on the back, if you have one check to make sure it is working, most won't activate until the unit gets warm, other issues are bad solder connections on the audio outputs causing intermittent shutdown, as a final inspection check speaker connections to the receiver and speakers.
Sep 18, 2011 | Denon AVR-1508 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
How do I reset my Denon avr-589? I would like to reset my reciever back to original settings.
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Jan 02, 2010 | Denon AVR-1508 Receiver
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
I want to get full surround sound out of my Denon AVR-1508 w/sub
hi there might be some problem with the link that u have hooked up with the speakers.
Jan 18, 2009 | Denon AVR-1508 Receiver
Denon AVR-1508 Receiver Logo
128 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
