Question about Whirlpool Washing Machines
I have a Kenmore-Whirlpool top loading washing machine, Model #11049722990. It works fine, but makes a screeching noise at the end of the spin cycle. What is the most likely cause of the problem, ad how do I repair it? Thanks in advance!
  • 1 more comment
  • johnhnhn Nov 13, 2010
    I think that it does this after the motor shuts off and as it is slowing down and coming to a stop. It has a high pitched to a stop. It has a squealing-screeching type of sound to it.
  • johnhnhn Nov 14, 2010
    Since it works OK, what are the consquences of continuing to use it as is? And how do I replace the brake?
  • johnhnhn Nov 15, 2010
    Thanks!
    President:
  • 1,654 Answers
First of all, I can only quess without hearing the noise first hand. I suspect that the brake on the motor is slipping. Does it do this after the motor shuts off on the spin cycle or is the motor still running? If it's after it shuts off I would suspect the brake. The coupling to the motor and transmission may also be going bad. I would have a tech check these items first. I can't think of anything else this might be. The couplings and agitator tabs wear out on these and cause simmilar problems
Posted on Nov 13, 2010
  • Dcramer531
    Dcramer531 Nov 14, 2010
    Then the only thing I can think of is the brake mechanism. I had a repair earlier this year on mune and when they were done the brake stopped the drum with a loud thump and before there was a slight squeal to the machine when it was stopping. I would have the brake checked to make sure it is working correct and like I said before, you should have them check the coupling and agitator tabs to save yourself another service call. I hope this helps.
  • Dcramer531
    Dcramer531 Nov 15, 2010
    I would not worry too much if the noise is bearable. Here are a few more tips on the brake and clutch and cover removal
    Check the clutch If its cracked or got bent or inner clutch pin is got loose or broken then in spin cycle you will hear a loud noise. Also problem related to dragging brake shoes.To verify this you need to remove the parts. Just pull agitator, loosen the spin basket nut 1/2 way out and pound on the top of nut till the spin basket breaks loose.Now pull motor out and turn the tranny coupler clockwise untill the basket starts to spin, if now its very hard to turn with one hand, you have dragging brake shoes. Now pull transmission out and pry down the brake shoes, but leave the spin tube in the washer. Now remove the spring,cam and brake shoes and replace them.The other possibility is faulty motor coupler that is rubbing the inner metal and parts causing noise,in this case the motor and motor coupler needs to be checked and replaced. To disassemble the machine.Please click on the links one by one for proper diagrams.http://i160.photobucket.com/albums/t200/... then click this one:----http://i160.photobucket.com/albums/t200/... then click this one:---http://i160.photobucket.com/albums/t200/... --------- Then click this one:---http://i160.photobucket.com/albums/t200/... --------
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Noise at the end of spin cycle
possible bearing going out in your barrel.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
