Question about Cobra 29 LTD CB Radio
I just got a cobra 29ltd army edition and i cant get the SWR right
    Guru:
  • 773 Answers
Takes some time to get it down if you are new to it. Here is a step by step instruction on setting it.....
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Posted on Nov 17, 2010
Trying to setup a cobra 29ltd chrome. Put on channel 20, switch set on cal, keyed up the mic, and when I turn the swr cal knob the needle won't move. Magnetic ant with acc outlet for power Any ideas
First, make sure that the CAL/SWR/RF switch is set to CAL. If you still can't move the needle, check the RF output. If the needle moves to the far right, you at least have output power, and something is wrong with the SWR circuitry. Does the needle move with incoming signals?? If the needle doesn't move, then you either have a damaged meter. If the needle moves on rec eived signals but not when you transmit and the switch is set to RF, then you most likely have a damaged transmitter output stage.
Oct 01, 2016 | Cobra 29 LTD CB Radio
I know vhf pretty well. But cbs uhhhh. I have a cobra 29ltd classic. My. Buddy blew diode. Wired backwards. I replaced diode. Now it's making a constant humm from speaker. The swr meter stopped.
did you replace it with one that is equal to the one that burnt .The one you replaced should have been the reverse polarity diode which should have been right near the smaller transformer .If this is the radio it looks like you should replace some of those electriclytic caps also.Did you replace the diode with the arrow pointing in the direction the arrow is pointing ?
Apr 28, 2016 | Cobra Radio Communications
Cobra 29ltd schematic dale earnhardt
It's the same as the standard 29LTD Classic. Here is a link to the schematic. http://www.cbtricks.com/radios/cobra/29ltd_chr/index.htm
Aug 24, 2014 | Radio Communications
29 cobra ltd brand new everything swr cant set my swr pegs out all the way to the right when i key up cant even get the right hight for my 4' firestick also the antenna light is very dim
If your coax isn't shorted somewhere (which can easily happen) then I would say the problem lies in your amplifier. Your amplifier needs to be matched to your radio by adjusting the input and output capacitors. Not many so called "techs" can do this and Bubba sure as hell don't know. It take proper equipment and the right parts to do the job right.
Aug 22, 2012 | Cobra 29 LTD CB Radio
New 29ltd army power in and all through radio but wont come on at all
This is not meant to be insulting but is CB/PA switch set to PA?
Squelch full counter clockwise?
RF Gain full clockwise?
Jul 30, 2011 | Cobra 29 LTD CB Radio
29 LTD CB Radio: all i have is a new 29ltd with a will 2000 ant whe...
Well, i,am wondering.what kind a problem you having.......all looks good to me....just key the mic.....and say Hi ....enjoy...........
May 18, 2010 | Cobra 29 LTD CB Radio
TO SETUP MY SWR, SHOULD I USE THE METER IN THE RADIO OR AN EXTERNAL SWR METER . THE SET IS THE NEW 29LTD BT. ALSO AT TIMES THE ANT LITE COMES ON WHEN TRANSMITTING. IS THIS NORMAL?
Always use an external meter to set SWR. If the ant. warning light comes on it indicates a problem with the SWR. Check it with external meter.
Oct 19, 2009 | Cobra 29 LTD CB Radio
I need the manual/s for a Cobra CB radio, 29LTD Classic,ser#105129711,manufactured 5/01. Thanks for any help you might have, This radio has a built in SWR meter and I need to know how to tune it or do I...
1) push the button marked S/RF / SWR / CAL to CAL
2) Hold in the button on the mic
3) Turn the SWR CAL knob until the needle is over set to the far right of the meter
4) flick the switch (in step 1) to SWR
Your SWR reading will be displayed. The more to the left the better..
Jun 22, 2009 | Radio Communications
Cobra 29 ltd when powered up error Y can anyone help me
Hi and welcome to FixYa,
Often an error code "Y" would indicate test/diagnostic result of the antenna. A communication equipment thus equipped would test the SWR and display this error code if:
  • no antenna detected; or
  • SWR of antenna is way too high.
Although am not familiar with the version of a Cobra 29LTD with this type of display. Could you pls post back the exact model of the radio, normally there would be two (2) more letters after the LTD something like Cobra 29LTD BT.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
137 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
