Question about HTC S620 Smartphone
JOGGERBAR im unable to scroll or turn volume up or down using the JOGGERBAR
  • Anonymous Feb 06, 2009
    i canot raise volume which button do i press
Get into joggr and you have the option to scroll,adjust volume etc you might have it on scroll let me know how you get on
Posted on Jun 23, 2008
I have a one touch tablet, is there a way to set it back to factory settings?
How to reset a Alcatel One Touch tablet?
If your tablet won't turn off, then follow the steps below. Press and hold Volume up and Power buttons until the reset interface appears on the screen. Scroll to the desired language using the Volume down button, then press the Power button. Scroll to wipe data/factory reset using the Volume down button.
Nov 26, 2016 | Tablets & eReaders
How do i turn off talkback mode and reboot the phone to factory settings
You can try the below if you are having Samsung Galaxy phone.
  1. Double-tap on the Settings icon to get to Settings.
  2. Scroll down to "Accessibility" using your two fingers.
  3. Double tap on the switch to turn it off. Talkback is now disabled on your Samsung Galaxy Core
And to reset to factory setting, follow the below steps.
To do a factory data reset, follow these steps:
  1. If your phone is on, turn it off.
  2. Press and hold the Volume up button and the Power button at the same time until the device turns on.
  3. Press the Volume down button to select "Recovery mode." If you need to navigate to the "Recovery mode" option, use the Volume up button to move the arrow and the Volume down button to select it.
  4. You'll see an image of an Android robot with a red exclamation mark and the words "No command."
  5. While holding down the Power button, press the Volume up button and release it.
  6. Use the volume buttons to scroll to "wipe data/factory reset" and press the Power button to select it.
  7. Scroll down to "Yes - erase all user data" and press the Power button to select it.
Your Android One device will erase all of your data and restart with its factory settings. You'll see the Welcome screen just as you did when you turned the device on for the first time.
May 16, 2016 | Cameras
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
  1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
  2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
  3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
  4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
  5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
  6. Use the volume buttons to move up and down through selection in this menu.
  7. Using the volume down button, scroll down to "Wipe data/factory reset"
  8. Tap Power hard key to select option.
  9. Scroll down to select "Yes, delete all user data".
  10. Tap the power button to select. Wiping and formatting data will take a few minutes.
  11. You will return back to the Android recovery screen menu.
  12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Dec 31, 2014 | Tablets & eReaders
It1351
try this one
try this note all data will be deleted
step 1. turn phone phone
step 2. hold the power button/ volume down button
step 3. use the volume down to select wipe/factory data reset
step 4. use powerbutton to confirm selection
or
Power OFF the handset
While OFF; Simultaneously press and hold the Volume Down, Camera, and
the Power keys for 10 seconds.
When the Android icon is displayed touch the Menu sensor key .
Scroll with the Volume Down key to "wipe data/factory reset" and press the
camera button.
Scroll with Volume Down keyto: "Yes -- delete all user data" and press the
camera button.
When Data wipe is completed the option "Reboot system now" is
highlighted, press the camera keyto reboot the device.
Jun 15, 2014 | Cell Phones
M950 turns on but wont go to home screen
You will need to factory data reset your phone if you are "hanging on startup" (stuck at logo) here is how:
WITH THE PHONE POWERED OFF --
Press and hold the volume up key.
Then press and hold the power key.
When the Samsung system starts release power key
When the Android system recovery appears, release the volume key.
Scroll to:
Wipe data factory reset using the volume down key.
Use the power key to select Wipe data factory reset.
When the options present scroll to "Yes."
Use the power key to select "Yes."
Use the volume down key to scroll to Reboot system now.
Use the power key to select Reboot system now.
Phone should now restart.
Nov 28, 2013 | Cell Phones
Unlock coby mid7048
  1. Turn off the unit completely.
  2. Press and hold the volume down (-) button.
  3. While holding down the volume down (-) button, press the power button to turn on the unit. Once you see Coby logo on the screen, you can release the power button, but you still need to keep holding the volume down (-) button until you see Android robot logo on the screen.
  4. The "Android system recovery" menu will appear on the screen. The volume up (+) button is used to scroll up in the menu list, while the volume down (-) button is used to scroll down. The power button is used to select and/or enter an option.
Jan 03, 2013 | Coby Kyros Tablet
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Scrolling
just hit the main menu botton twice it will automaticly play all for you.
Jun 20, 2009 | GE JASRM24912 Remote Control
HTC S620 Smartphone Logo
133 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
