My printer is not printing and has full ink, neither making copies the paper comes clean, it looks like is printing but is not.
    Scholar:
  • 54 Answers
Clean the whole area in printer and on cartridge where the two items meet. Use manufacturer's instructions, and be careful about static; stay off the carpet, etc. Set the cartridge on a damp rag for 15 min (watch it to make sure all ink does not run out)
Posted on Nov 12, 2010
Printer ink cartridges full but nothing comes on the paper
Try those solution:
- Clean the head within the printer maintenance mode.
- If you filled the cartridges by yourself, make sure that you empty the cartridges of air after filling it with ink!
Mar 18, 2012 | Office Equipment & Supplies
Making noise like its printing but nothing comes onto the paper
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
I replaced the black cartridge & when it said to run the alignment the paper comes out and looks like it's OK but the message comes up that slignment failed. Then if I ignore it and try to make a...
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Aug 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
Jan 20, 2010 | Canon BubbleJet i320 Printer
Black ink not working
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
Prints Blank Pages...even though ink is full.
problem is likely to be the print head, the ink can dry up inside the print head and block fresh ink from flowing.
you can get print head cleaning solution from ebay, which sometimes works, or else go here to get your replacement print head
www.kodak.com/gb/en/consumer/products/printing-supplies/printhead.../default.htm
the one i have is a clip in clip out part
May 03, 2017 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother DCP-150C problem = nothing is coming out of the paper eve
Best thing you can do is first make sure all packing has been removed off the new ctgs, sometimes manufactureres have small tape covering the head which causes this issue, also if ctgs look good then go to print driver right click and go to properties and look for utilites or diagnostics and run full head cleaning to make sure there isn't dried ink clogging lines.
Hope it helps
TankMurdock
Apr 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Blank paper
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Damm printer
did you use generic ink carts before?
It seems that the ink has clogged the whole print head.
Do use original brother ink carts which have special cleaning fluid within the ink.
After that run the manual ink cleaning procedure by pressing ink etc.
Make sure that all carts are placed well and are secured.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
43 people viewed this question
jasbo
jasbo
