Question about Maytag Washing Machines
Water is leaking out from the bottom of my Maytag top load washer Model A612, my floor is soaked! do I need a new washer or should I unplug it, tip it over & see what's wrong? thanks for yor help.
  • 618 Answers
Remove two screws from the front panel, tilt out and remove or there may be two clips under the front panel near the sides that need be depressed with a putty knife. Run a load and see where the water is coming from . The clamps that hold the hoses on the pump and tub rot off quite often.
Posted on Nov 12, 2010
We have a Maytag A612 washer. Today it wouldn't fill all the way with cold water (for a cold water load). If I hit the Warm or Hot button, it resumes filling with Hot water, but I don't want Hot so I hit...
Turn off the cold water faucet.
Remove the water hose from the machine and the faucet.
Clean out the filter screen in the washer water valve.
Look in the hose for a secondary screen and clean it also if one if there.
Not all hoses have screens.
All water valves do have screens.
Sep 05, 2010 | Maytag SAV4655A Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag washer is about 15 years old. Suddenly
Without a model number, but with the age, I can only assume that this is a Dependable Drive wash system.
This system utilizes a drive belt and a pump belt and it is recommended they be replaced together after every13 years of normal use. They are very simple to install with no teardown or tools needed. The belts have installation instructions printed on the package.
1. Drive Belt
http://www.repairclinic.com/SSPartDetail.aspx?s=t-a612-%3d%3di437301&PartID=437301
2. Pump Belt
http://www.repairclinic.com/SSPartDetail.aspx?s=t-a612-%3d%3di437300&PartID=437300
The pump belt must be adjusted to the tension requirements written on the package. See link below.
http://www.affordableappliance.com/Tips/Maytagbelts.htm
3. Parts breakdown/disassembly procedures.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
Other issues could also cause the same symptoms but the belts at this age is the 1st suspect.
Aug 30, 2009 | Washing Machines
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Washer spins freely but clothes remain very wet
The two possibilities of which come to mind are, something in pump slowing the water outlet, belt loose or needing replacement. Sometimes an article gets over the barrell and sucked into the pump still allowing some water to pass by, but the belt needing to be replaced would prably be my first check. both need Power disconnect then cabinet panel pulled to view both the pump and belt
Feb 09, 2009 | Maytag PAV2300 Top Load Washer
Maytag a612 washer with leaking drain hose
There are 2 bolts on the underside of the machine top at the front. Removing them will free the top from the body.
Dec 21, 2008 | Maytag SAV4655A Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
227 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
