Question about Freezers
My freezer's motor is making a funny noise what does it mean
  • 134 Answers
It probably means it has a bearing goin out in it they are usually pretty easy to replace if you go back to the store you bought it from thay should be able to order oyu a new one it is something that is reasonable priced at least on most occasions,.
Posted on Nov 12, 2010
Freezer does not work , it was shut down for a year , what can i do ?
Can you provide a little more information? Like what happens when you plug it in?? Nothing? Funny noise?? Motor runs but no cooling occurs?
Nov 17, 2014 | Freezers
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire freezer making noises
evaporator is probably frozen up
Apr 23, 2012 | Frigidaire Freezers
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
Motor makes noise and not sure if it is using a lot of electricity
it's normal. because due to running of compressor and motor this type of sound is developed...............have a nice day :-)
May 15, 2009 | Frigidaire 20 cu. ft. / 566 liter Chest...
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
Changing Freezers
If your products are already in the frozen state the answer is yes, you can make an immediate transfer. Normally a couple of hours run to allow the temperatures to stabilize is sufficient. The cool down run time also insures the the unit is functioning properly. If you plug it in and transfer the products right away make frequent checks to insure proper operation.
Aug 16, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
73 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
