Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Power surge fried our unit
We lost electrical service to our whole house and the service line (from the pole) had to be replaced. There was apparently a power surge from which our DGB-600BC was not protected. When we plug it in we get nothing--no clock, no lights, and worst of all no coffee! What to do?
  • dmurphy191 Jul 09, 2008
    The coffee pot has no power. I came home after a storm, the pot was off. I checked breakers and the outlet and everything is fine. I tried plugging it into a different outlet that I knew was working, still no power. The coffee maker is only 1 1/2 yrs old. Any suggestions?
  • NC Ken Jan 19, 2009
    My situation is exactly as described, except mine is only two months old. Will try the warrantee route, and watch for other comments or fixes here.
Contact cuisinart and see if the will replace it under warrenty. This happened to mine, but they would not replace mine because it was a refurbished model. I am going to rip mine apart to see if I can fix it this weekend.
Posted on Aug 09, 2008
Won't turn on. Power went out to the whole house when roof was being replaced. Tell me where reset button is
What won't turn on? If the entire house lost electricity, that means that either the main electric line was severed or the main breaker in your panel was tripped. I suspect the latter. Go to your main electrical panel, open the door and look at the top of the panel. There should be one large breaker marked either 100 125 150 or 200 A. This is your main breaker. Turn it off and turn it on.
If you don't know where your electrical panel is, go outside and look to see where the electric wire comes from the pole to your house. There will be a meter pan here with a glass housing on it. Your panel is almost always directly opposite of that meter inside your house so figure out what room that aligns with and that's where your panel is. I hope this helps.
Jan 04, 2016 | Home
A power surge fried my Epson Home Lite projector HDMI port......how much does it cost to repair or is it pretty easy to buy the part & fix yourself?
I have lost many things to power surges; sometimes it's only the electric cord (can be replaced), sometimes it's the battery (for lap tops), sometimes it's the electrical socket itself (try plugging into a different one). Worst case scenario the whole thing is fried (not all power surges are equal) now that I have everything plugged into surge protectors I only see them fry (beats losing another computer) try plugging it in without the surge protector or extension cord (if you were using one).
Oct 17, 2013 | Video Game Consoles & Games
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Came home from work to find that my circut breaker was tripped for my furnace...what and why caused this...i flipped the breaker back on and smelled like it fried the control board....why did it do this
The most likely cause was a power surge. The surge from the power line into your house wil fry the board and trip the breaker at the same time. Then when you turn the breaker back on it will continue to fry the board....
Whole house surge protection can help to stop some of the surges, but may not toally protect you from them. Some are too large to be completely stopped with normal surge protection devices.
There are many deivices out that will provide surge protection and some like these that will provide surge protection and can help to save you money.
Check it out here...
www.cutyourelectricbillnow.com
Heatman101
Mar 13, 2010 | Heating & Cooling
Power surge fried Frigidare FEB24S2ASB
The electronic oven control has gone bad. The repair is a lot less expensive than the replacement of the whole stove. Part number is 903091-9051 at about 165.00 retail. You can fix rather than replace whole stove. Hope this helps.
Mar 04, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Liftmaster 3280 completely unresponsive after electrical surge at home? I opened it up and i see nothing wrong. I was expecting maybe board is fried or something .... do not know what to do? I am new to my...
THEY CAN LOSE PROGRAMING IN ELECTRICAL STORMS OR POWER SURGES. UNPLUG THE UNIT TO RESET THE CIRCUIT BOARD.
REPROGRAM ALL REMOTES.
IF YOU STILL GET NO RESPONSE YOU PROBABLY HAVE A FRIED BOARD.
YOU CAN GET TROUBLESHOOTING INFO IN THE OWNERSMANUAL.
IF NOTHING ELSE WORKS CALL A LOCAL GARAGE DOOR REPAIR COMPANY. IF YOU REMOVE THE UNIT AND TAKE IT TO THEM MOST WILL DO FREE DIAGNOSTICS IN HOPE OF SELLING YOU THE REPAIR/PARTS/REPLACEMENT - BE SURE TO ASK IF THERE IS A CHARGE
HOPE THIS HELPS
Jan 04, 2010 | liftmaster Chamberlain Garage Door Opener...
Micro 6654438991 power surge from pole, light works, panel dead
Sounds like you should get estimates and turn in on homeowners insurance. Power surges are very destructive and you have lost the control board at least and maybe some switches. Eric
Aug 08, 2009 | Whirlpool GH7145XF Microwave Oven
KitchenAid dishwasher loss of power
Electrical storms can burn out electronic components. Consider investing in whole house surge protection.
If you need assistance in selecting or installing surge protection on main power line, email me buffalonymann@yahoo.com
Jul 30, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Tv dont turn on
Yes, there was a power surge, most likely. Use a surge protector or battery backup nex time. The thing's trash.
Aug 14, 2007 | Toshiba 24AF45 24" TV
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
270 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
