Question about Linksys Wireless-G WRT54G Router
It says my computer is connected to linksys but it will not hook up to the internet? Through plug in or wireless.
    Master:
  • 515 Answers
There might be several router in your area with that SSID of Linksys. You can change the SSID or your router to something more specific. You can connect to the router by using the IP address of the internal port of the router. You should be able to see that on the shell of the router or on the manual. Be sure to use the IP address on the same subnet on your computer. If your router is with an IP address of 192.168.0.1, then you might use 192.168.0.3 on your computer. Then you can open a web page on your computer with the IP address of your router and then you should see the admin page of your router and login in there with the user name and password specified on your manual or the shell of the router or from the web site of the manufacturer for the specific router. Then you will see the wireless tab and configure it. If you need more details, you can check the support web site of the manufacturer and search for the specific device.
Posted on Nov 12, 2010
Where do i put hinternet connection cord at?
1. Go to Best Buy. Get a Linksys wireless router. Hook up your internet to the slot in the back that says INTERNET. Then attach an internet wire into slot 1. Plug the other end into your computer. Repeat with any other computers. Put the CD in any computer hooked up with the Linksys. Set it so wireless connections are allowed and set a password. Use the internet channel, wait until your Linksys pops up, and enter you password. You're good to go.
Note: I was talking about this Linksys: http://www.linksysbycisco.com/US/en/supp...
2. Get a $40 Wi-Fi adapter and hook it up to your computer (assuming it has internet). After setup, You will have Wi-Fi, but it has a tiny range. I recommend the router. The router has a MUCH larger range and costs $20-$120 depending on how fast and how large of a range you want. Any router will work as long as it's wireless.
Feb 26, 2011 | Nintendo Dsi Pink Console
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
Linksys wireless for my desktop
Your Router might be locked on your laptop, try this,
1. Unplug the power cord from the wireless router
2. Wait 10 seconds.
3. Plug the router back in.
hope this helps
Nov 17, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
I CAN NOT CONNECT TO THE INTERNET ..using Linksy wireless remote
the wireless card installed to your computer is working..as you said you can view all wireless networks...your computer is good too...the only issue is you cant connect to the wireless router...
turn off and unplug the power cable of the Modem
turn off and unplug the power cable the router
wait for 30 seconds
plug in and turn on the modem, wait for all the light turn to solid green ( no blinking lights )
then power on the router
if you saw the wireless icon light turn solid...
go to your computer...right click the wireless icon...select repair
if this doesnt work....reset your internet router by press and hold the reset button behind the router near the power plug (atleast 15 sec)
then connect your PC..the wireless network dont have the WEP key anymore because of the reset..you can reconfigure and put back the WEP key when you get connected.
Mar 16, 2009 | E-Machines (T2958) PC Desktop
I have just purchased the linksys wireless router and hooked it up according to the instructions numerous times. After putting the installation disk in it stays i am not hooked up properly when i know i...
Hi
Please refer the link http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US/Layout&cid=1166859678292&pagename=Linksys/Common/VisitorWrapper
it will provide EasyLink Connect tool. EasyLink Connect is a first-time setup application that automates the setup of your Linksys router, including:
  • Cabling Instructions
  • Internet connection configuration
  • Wireless connection and security setup
  • Other devices and computers addition
Please Vote if this is helpful
Jan 02, 2009 | Linksys Wireless-G Broadband Router
LINKSYSBYCISCO WIRELESS ROUTER
this is what is happening, please get me solution email is nickesdad51@yahoo.com
Dec 08, 2008 | Linksys WRT160N Wireless Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Linksys wireless problem
hiya krazy327... sorry to hear about your prob.. we,ve all been here at some point!
Can you let me know if it is one specific computer that the problem is with?
If so .. how are you wired to the router "True" wireless or usb/ethernet gateway from the router?
Regards Faggly
Mar 18, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
333 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
