Question about Weedeater 2 Speed Gas Blower FL1500LE ()
Blower must remain @ 1/2 choke in order to continue to run
  • 718 Answers
You need to get a carb rebuild kit. there is a number stamped on your carb usually walbro carb it will be stamped WT# # ( # ) take that number to your local repair shop or on line and get a kit.
Posted on Nov 13, 2010
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
My br420c blower runs fine for about 20 seconds and then shuts off like the switch has been turned off
possibility 1) It sounds like it is sucking air with the gasoline. 2) don't rush the choke, leave it running on high with 1/2 choke. When you go to move the choke to off, move it very very slowly while the governor can catch up and raise the revs. Or slow the revs down before turning the choke off.
Oct 23, 2013 | Stihl Br420c Magnum
The best way to start cold husqv leaf blower 145
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
Will not continue to run after relasing choke, no
you have a fuel starvation (lean condition) issue
fuel system needs cleaning
fuel lines
filter
carburetor cleaning and replace gaskets/diaphragms
Sep 28, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
Snow blower is running sluggish with the choke in the on position
It sounds like you my need to rebuild and clean the carburator. Or you have an air leak between the carb and the cylinder.
Jan 28, 2009 | Toro Blowers Rake and Vac - Electric...
Weedeater 2 Speed Gas Blower FL1500LE () Logo
258 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
willy15
 steve
steve
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
