Question about Polk Audio RTi100 Main / Stereo Speaker
The binding posts on one of my advent loudspeakers have come disconnected from inside the cabinet; how can i remedy the problem?
Our new Moen kitchen faucet won't stay over on right side, keeps coming to center. Can't use right side! Ahhhhrg!!
If it has a spout pull out spray it is most likely binding on something inside the cabinet. If not call 1-800-buy- moen. great customer support
Dec 14, 2016 | Moen Plumbing
Advent model HT3251A
What is the circuit designation of the part in question? It should be marked on the board as Rxxx or FBxxx. Post that here. That should allow us to identify what it is at the very least.
Dan
May 29, 2008 | Recoton Advent Advent HT3251A TV
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
How do you remove the passenger side rear door panel in a 2006 Fiat Punto
1 Prise out the trim cap and undo the screw securing the exterior mirror inner trim panel of door
2 Where a manually-adjustable exterior mirror is fitted, prise the rubber cover off the adjustment lever, then unscrew and remove the locking collar using pointed-nose pliers.
3 Pull the panel from its location to disengage the retaining clips. Disconnect the loudspeaker wiring connector and remove the panel.
4 Lift off the trim caps, undo the retaining screws, then remove the door interior handle surround.
5 Carefully prise off the loudspeaker grille then undo the three loudspeaker retaining screws. Withdraw the speaker from the door and disconnect the wiring connectors.
6 Undo the three retaining screws in the loudspeaker aperture, and the single screw in the oddments pocket just below the aperture.
7 Lift out the loudspeaker protective cover and withdraw the loudspeaker wiring from the base of the cover.
8 Prise out the trim cap and undo the screw securing the rear of the trim panel to the door frame of Fiat Punto car.
9 Undo the screw at the upper front corner of the panel, and the remaining four screws securing the lower edge of the panel to the door frame.
10 Using a suitable forked tool inserted between the door and the trim panel of Fiat Punto, release the press-stud clips located around the edge of the panel, then lift the trim panel upward.
11 Pull the panel from the door, noting that the lower window aperture weatherstrip is integral with the trim panel and must be released from tie door as the panel is withdrawn.
12 If work is to be carried out on the door internal components, it will be necessary to remove the plastic sealing sheet from the inside of the door. Start at one comer of the sheet and carefully peel it away, using a sharp blade to split the sealant bead, if necessary.
13 Store the detached sealing sheet such that it cannot become contaminated with dust; this will allow it to be re-used later.
Source (with illustrations) - Door inner trim panel removal and refitting FIAT Punto
Feb 22, 2013 | Fiat Grande Cars & Trucks
I connected my QSC K12 to a powersupply that was dimmed, The power. Switch was turned on when I connected the power cord and I heard a booming sound that came with a spark.I suppose the fuse has to be...
This can be found on the QSC Support site and appears to be the only reference to the problem on these loudspeakers. Check the site at the link below:
Open up the cabinet, take a look and tighten up the clips that hold the fuse for the horn in place...Tech. support said they've seen that problem many times in the past.
http://forum.qscaudio.com/forum/search.php?fid[]=4&sid=f7645ff1016aafa7fd5b992d30770052
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | QSC K Series K8 2-way 8" Active...
My son took my Large Advent speakers to college and now both of the tweeters are not working. I tried hooking up other tweeters and they don't work either. The woofers sound fine.
Check the crossover boards inside the cabinets, look for burns or signs of melting, sniff them too!
If you're in luck, u may even find fuses on there, good luck
Mar 25, 2011 | Audio Players & Recorders
How does the speaker wire physically connect to the Harman Kardon DPR 2005?
You have 7 pairs of plastic binding posts.
Unscrew the post until it comes out an eighth of an inch.
You will see two spaces in the black plastic one at the top and one at the bottom of each binding post. That space is for the wire. Strip half an inch of jacket off your speaker wire and slip the stripped part inside the hole and screw the binding post down on it and it will squeeze the wire against the contacts.
If you find that difficult since the posts are so close tommorow, a "Banana Jack" may be put on the wire then pushed into the hole in the binding post.
It is difficult to describe in writing but onece you see it you will understand.
Black posts are the negative, they are all on a common ground. Coloured posts are positive.
Dec 23, 2009 | Harman Kardon DPR 2005 Receiver
Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
May 29, 2008 | Recoton Advent Advent Calypso Main /...
UMC 15/4 15
Hi.
Most manufacturers fit the speakers to cabinet with A rubber doughnut or thick rubber washer between each speaker mounting hole & tv cabinet this prevents any vibration from speaker body being transfered to the cabinet.
If yours arent mounted in this way it will be your problem.
http://dysonmanuals.llc.nu/
Chris..
Feb 06, 2008 | Televison & Video
Polk Audio RTi100 Main / Stereo Speaker Logo
15 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
