Question about D-Link DSL 300G+ (DSL-300G+) Modem
Actually involves a D-Link DSL 300G Modem. Loses
Actually involves a D-Link DSL 300G Modem. Loses connection but power still on. Unplug power, reinsert, modem eventually reconnects with ISP server but eventually connection is lost once again. Repeat unplug and reinsert power plug. Frustrating! Thanks.
  • bpnewman Nov 13, 2010
    Not yet. Having difficulty downloading the firmware from softpedia.com even tho went thru the entire, rather extensive, convoluted registration process???????? Still trying.
  • 1,679 Answers
This is common issue with the D-Link modems. There is a firmware update released by D-link.
Download the firmware update and install. It should fix the issue.
Download Firmware
Let us know if it fixed the problem
* Please rate this solution and comment on it
Posted on Nov 12, 2010
Internet setup
It should work "out-of-the-box".
Be sure to connect using "straight-through" (not "cross-over") Ethernet cables.
Connect from the 'WAN' port on the router to your DSL-modem (or cable-modem).
Power-off the DSL/Cable modem.
Power-on the DSL/Cable modem.
Power-off the D-Link.
Power-on the D-Link.
Reboot your computer.
You should be good.
Mar 09, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
How do i connect my tp link router to my dsl modem
* 1 Unplug your DSL modem and D-Link router. In order for the network to properly recognize its devices, these devices must be attached in a specific order.
* 2 Plug in your DSL modem's power cord. There is usually no power button on a modem. Simply plugging in its electrical cable will turn it on. Give your DSL modem a couple minutes to re-establish its connection to AT&T's network before taking any further action.
* 3 Plug in your D-Link router's power cord. Like the DSL modem, this router will probably not have a power switch; simply plug in the power cable, and it turns on. Let the D-Link router sit for a couple minutes while it establishes its connection to the DSL modem and AT&T's network.
* 4 Physically attach your computer to the router with an Ethernet cable. Even if the router and modem are wireless, a physical connection must be established to properly configure the router. If this is not a wireless network, then your setup procedure is essentially complete.
To access a D-Link router on your network, open an Internet browser and navigate to the 192.168.0.1 address. This will bring you to your D-Link router's interface. The default User Name is "admin" (without the quotes), and there is no password. Enter the User Name and click the "Log In" button. This will bring you to the Setup window. Refer to your D-Link router's documentation for changing the default password (highly recommended) and forwarding ports.
If this is a wireless network, you have a couple further steps. First, change your network's SSID (Service Set Identifier) title, so that you can recognize it when other wireless networks are nearby. Also, choose your wireless encryption and passphrase. WPA2 (Wi-Fi Protected Access 2) is a solid option. Specific instructions depend on your model of D-Link router; so refer to your documentation (which can usually be found at the manufacturer's website if you do not have it on hand).
* 5 Disconnect the Ethernet cable from your computer. Your new wireless network should be visible with your computer's wireless adapter. Windows and OS X will notify you of networks in range when your adapter is active. Connect to the one with your SSID, and enter the passphrase.
Sep 06, 2011 | Computers & Internet
Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
Nov 05, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
The internet connection keeps disappearing.
Change the router's IP address to (192.168.10.1) maybe you have an IP conflict between the modem and router.
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
My D-Link > DSL 300g ADSL Modem is constantly loosing it ADSL Link
Modems do this once they get older. Either get a new one or wait for it to reconnect.
Jul 07, 2008 | Computers & Internet
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Can,t access modem
disable all the fire walls
turn off all the security soft in urs pc
rescet urs modem 1s
then
try connecting the d link with the perfect jack to the perfect conector
thank you
Jan 18, 2008 | D-Link DSL 300 Modem
D-Link DSL 300G+ (DSL-300G+) Modem Logo
381 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
