Question about Mustek MP70C Portable DVD Player
Mustek mp70c disk not available - Mustek MP70C Portable DVD Player
  • zooter2005_m Feb 18, 2015
    Noticed that the head was to the outer left of the player.
    Used a small screwdriver to spin the plastic gear to move the head to the center of the player.
    Disks load now and the player works.
I need a dutch manual fore Mustek ScanExpress F35
The dutch manual is not available in the Mustek web site. It might have been supplied in the Product Disk. However, the manual is available in English language in the following link:
http://www.mustek.com.tw/html/prod_2010/Manual/82-328-00020.pdf
For assiatnce , you may contact Mustek Europe at the following contact details:
MUST International B.V.
Celsiusweg 32-58 , 5928 PR Venlo, The Netherlands
Product Questions/ Technical Support
Email:tsupport@mustek.com.tw
Wholesale Inquiries
Email:europe.sales@mustek.com.tw
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
1. I need a driver for Mustek ScanExpress 6000 P under Windows XP. 2. Where is free download in internet?
Mustek website. Handheld and Flatbed Scanners. The latest drivers are available for free download here. ...(http://www.mustek.com/mustek/Support.php) please rate
Dec 06, 2010 | Mustek ScanExpress 12000 SP Flatbed...
I power it up and insert a disc and it says Wrong Region on the screen. This is a Canadian unit that has worked fine for two years now, and I've tried several different DVDs which work fine on my larger...
If you have relocated then the region code may need to be changed. However using region 0 is most practical. Clean the optical head of the player with a CD/DVD cleaner too & see if it responds............sodeep
Sep 25, 2009 | Mustek MP70C Portable DVD Player
SUPER slow charging
Sounds like your battery is shot. replace it.
Jun 15, 2009 | Mustek MP70C Portable DVD Player
Mustek scanner will not work with vista
can you tell me whyno drivers for vista are available from mustek for my bearpaw 4800 ta pro . Is it possible somehow to get the scanner working ? or is it throw it in the bin time! Thanks Ted
Feb 24, 2009 | Mustek Bear Paw 4800 TA Pro Flatbed...
Mustek1248 scanner installation disc will not work with Vista
the drivers on the disk is proberly not vista compatible so that means you need to download the drivers try a search engine and search "MUSTEK 1248 SCANNER DRIVER" the results should come up with a mustek site and you can download the drivers from there for vista if they are available.
May 13, 2008 | Office Equipment & Supplies
MUSTEK 7" pORTABLE dvd PLAYER lcd PROBLEM
You might need to adjust the settings by pressing the LCD button then using the up/down/left/right arrows on the player or remote to change color or brightness. If this doesnt work, your screen might be shot. There isn't much you can do if thats the case.
Nov 03, 2007 | Mustek MP70C Portable DVD Player
Portable mustek dvd player
try this: power up your dvd without a disc. using your remote keypad input 9735. a secret menu should apprear. select your region code or choose 0 which will allow all discs to play. this will work with the mp70c but not with all mustek models. other solutions are available with an exhaustive google search
Feb 11, 2007 | Mustek MP70C Portable DVD Player
Mustek MP70C Portable DVD Player Logo
80 people viewed this question
Top Mustek Televison & Video Experts
Jonathon summesfield
richie46
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
