I am trying to run monster cable along the baseboards of my wall and need a fastener to secure the cable to the wall...any ideas?
  • 1,512 Answers
Hi jas
i would use hot glue. It sets real fast and is easy to administer. Put a dab on the cable, stretch, and secure into place. Hold for bout 5 secs, then on to the next spot. in this way you can tidy the lead dress as you go. If you dont wish to see the cable, I would use some square section conduit that has a clip down lid. You can get it from electrical wholesalers for about $10 a 3m length. The best of this stuff has double sided tape to fix it to the wall, however the cost goes up to like $40 a length
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 19, 2008
2007 ducati monster 695 doesn't start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.ducatimonster.org/forums/tech/197818-monster-695-wont-start-dealer-no-help.html
07 695 will not start sometimes
http://kuixihe.com/Downloads/How%20to%20repair%20and%20maintain%20Ducati%20695.pdf
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Apr 07, 2014 | 2007 Ducati Monster 695
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
Ducati monster wont start
2005 Ducati Monster 620 Wont Start
http://www.ducatimonster.org/forums/tech/205386-2006-monster-620-wont-start-just-clicks-when-i-press-start.html
2004 2006 Ducati Monster 400 620 Motorcycles Service Repair Manual Highly...
Ducati Maintenance
Dec 20, 2012 | 2002 Ducati Monster 620s i.e.
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Just bought a 2007 ducati monster s4r with 1749 miles that seemed to run fine until after a couple hour ride. the next day, the oil light and maintenance warning came on it but started, then suddenly shut...
Hi, Mr_sixtomerc and the usual suspects are:
Bike wont turn over Tried recharging battery and then new one too Clicking...
Ducati Monster won start fixed see how
Ducati Monster S4R 2003 2006 Factory Service Repair Manual Download...
Ducati Maintenance
Apr 21, 2011 | 2007 Ducati Monster S4R Testastretta
I have to cut a slot to insert a low voltage wire. Is the router the way to go. 50 foot run. I have to remove the baseboard so this is right at carpet level. Any ideas that would help me keep it clean...
If you are going to remove the baseboard, you will probably find that the drywall does not go all of the way to the floor, so you have a groove already available to you. If the existing gap is not sufficient, you could plane of the bottom back edge of the baseboard. And I suppose you would have just chosen to go through the floor if you had an unfinished basement (or crawl space) below the wall in question.
Apr 17, 2010 | BITS Rotozip Dr1 6 Amp Drywall Router...
Electric baseboard heater worked last week. but when I
The wall thermostat will click even if there is no power. You will need an electric metere to trace down the problem. May be a bad breaker, bad limit switch or the element could have went bad. You need to follow the electric and see what is interupting the flow.
Nov 12, 2009 | Fahrenheat FBE15002 Baseboard Heater
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Well really its not a problem, its actually quiet simple really
I have always used Monster flat wire as it can be placed under along the carpet and the wall without leaving bumps under the carpet and it can also be painted if you need to run it exposed up a wall
Bill
Dec 13, 2008 | Philips FR965DHT Receiver
Honeywell HZ517 Baseboard Heater
You can try to disassemble the heater and look for something wrong like a loose wire: in order to do so: Unplug the heater and let it cool completely before disassembling it. Remove the rear grille and the control knobs. Remove the front grille by unscrewing the fasteners on the back of the housing. Remove the front grille by lifting the control housing and pulling the front grille toward you. The motor, fan, and heating element are now accessible for testing and repair. Remove the thermostat from the control housing and disconnect the wires. Remove the heat control's mounting screws and clips to access and disconnect wires. Good luck
Nov 28, 2005 | Honeywell HZ517 Baseboard Heater
 Grubhead
Grubhead
