Question about D-Link AirPlus DI-524 Wireless Router
Power on, status light blinking, wlan blinking, 1 & 2 blinking, but cannot pick up internet on laptop.
    President:
  • 1,082 Answers
Is this a new installation? Or did it just happen, and was working before? Are you using DSL service or cable or dial up? Not enough info....
If it was working before, and suddenly stopped, then first thing to do is unplug the router for 30 seconds or so, then plug it back in.
If it was working on the laptop and stopped working, then you need to find the connection icon in the system tray (next to the clock) and right click on it, choose REPAIR from the popup. Let it finish and try to connect again.
If new installation, did you follow directions to install and use?
Open your Internet Options, and "connect" to the network. Wizard will walk you through it.
Start with the above - If no help then call back here.
Posted on Nov 12, 2010
I have a Belkin N wireless router, model F5D8236-4 v1. I am unable to connect to the internet using the router and I've even tried resetting the router with no luck. The "modem" light on the...
i have a belkin N wireless router model:F5D8236-4 v1 i have had it installed on my computer but it has since been wiped so there is no trace of me having it installed, since this i have moved home and ost the disk that came with it but i need to put the router back on due to my daughter having a laptop, how would i get the software for it if i have no disk?? please help!!!!!!!!!!!
Jan 07, 2011 | Belkin (F5D7231-4) Wireless Router
I have a Linksys WRT54G2 Router, It Has Worked Fine For About A Year, And Just Suddenly It Has Problems, The WLaN Light Isn't On At All, The Power Light Is Just Blinking At A Steady Rate. I Can't Access...
Please make sure that Power, Internet and Wireless Light (or LAN light if trying to connect with Ethernet cable) is there on router if you are trying to connect it wireless .
And if only Power light is there only.Please try to power cycle the router ( turn off the router from power supply wait for a minute, plug the power supply back) and then again check the light status.
Even after this if same light status is there please try to reset the router ( there will be small pinhole button on the back side of router) just press it for 15 seconds and then release it.Wait for 2 mins and check the light status again.
It will fix your problem.
Please share the results.
Dec 09, 2010 | Linksys WRT54G2 Wireless Router
Should the status light be blinking?
you should call the wireless manager.
good luck.
Jul 26, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Laptops not picking up on wireless signal
You will need to replace the router. This is typical of the failure pattern of all wireless routers. If you continued using the router on the wireless you would begin to notice those connected by wire disconnected and then quickly reconnecting again.
Unfortunetly this is typical of any home grade wireless router after 1-2 years of use or age. About all you can do is to do a hard reset and/or upgrade the router system software. That can regain use of the wifi for a while but it will fail again usually within a few weeks or days.
Best advice is to replace it with a new one. NetGear or D-Links are both reccomended. Linksys is not. If you check out the sales you should be able to find a good replacement for less than what you paid for the one you have giving you trouble. We replace about 2-3 wireless routers a week with these problems. Have tried fixing them even with the factory tech rep on the phone and in the end just ended up junking them.
May 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
Hi , my d- link wireless router just stopped working yesterday. I can't seem to get it to connect to the internet and none of the laptops are getting wireless internet. There are 2 lights that are blinking...
Verify the connections are correct, The WAN port should be connected to the Cable/DSL modem. Then do a hard reset (hold in the reset button for 30 secs). If this doesn't work, try another router to isolate the problem.
Sep 03, 2009 | D-Link DIR-625 (790069292637) Wireless...
DI-524 version D router problems
you need to open the configuration of the router. Read the manual in order to access on configuration. Once you access .. you can manually configure the router, and set what do you want.
Jul 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
What lights should be on?
Who is your internet service provider?
Jul 29, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Router not working, help please!
You may may need to configure your D-Link to use your type of internet! Try following the Quick Install Guide which can be found here: ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip The WLAN light doesn't come on probably because you have the wireless disabled, which can be re-enabled once in the configuration for the wireless(in the document mentioned above) If you are having any difficulty following the guide or have folloed the guid and still can't connect, please get back to me regards, babb
May 14, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
390 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
