Question about Home
I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 21666 4-16-86 We did build our house in 1986 ...the toilet is an older model but is in great condition except that the Hushflo valve has stopped working .Just need to know if there is a replacement kit for the inside of the tank available.... Thanks very much
  • 3,828 Answers
Picture is of a kohler rialto
looks like you can get the parts or retro fit newer kohler flush parts
ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
Posted on Apr 28, 2017
dragonsthatk
  • 547 Answers
SOURCE: Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Posted on Feb 23, 2009
  • 659 Answers
SOURCE: PLUMBSHOP HUSHFLO #516 Toilet anti-siphon/valve
Usually, there is a diaphram located at the needle valve that can be removed and cleaned and or replaced. If you know you have grit in the water, then you are right, that will cause problems with the fill valve not fully closing.
Posted on Mar 20, 2009
  • 16 Answers
SOURCE: hushflo valve
fluid masters are cheap and available every where i would just replace it
Posted on May 03, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Running toilet
You need to replace the float system. This will fix the problem will take you about 15 minutes and will cost you about 15 dollars to due it yourself. This is not the flapper, rather this is the float and the water inlet system
Posted on Jun 01, 2009
phmaddnes
  • 24 Answers
SOURCE: can't change the toilet seat that broke
Kohler Rialto Toilet seat replacement.
Use dremel to cut off old bolt and allow it to fall into the black abyss that is the genius of Kohler engineering. Enlarge the hole to 3/8. I worked up to that size slowly increasing bit size so as not to crack porcelin. At Home Depot I bought a 1/4 x 20 x20mm "Insert Nut" and a good 2 part epoxy meant for metal and ceramic. Gently tap the Insert nut about 1/2 way into the hole and apply epoxy all the way around. Continue tapping the insert nut until it is flush. Clean off excess epoxy and allow to set. Now attach any standard round toilet seat using the standard 1/4 nut that comes with it. I used a Kohler "Cachet" round toilet seat to replace the Kohler "French Curve" that comes standard with the Rialto. All in all it should take you about 1/2 hour.
Happy Fixing!
Posted on Jul 03, 2009
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
Apr 18, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
After flushing my Kohler 3386 Rialto Toilet the top of the valve assembly shoots water out while refilling the tank wich hits the tank top and leaks down the front. What do I need to do to fix this? ...
sometimes removing the 3 or 4 screws that hold the top of assemble and separating the assemble will dislodge debri..and adjust the seat so that the water comes out of the small tube into the overflow tube like it should.
Nov 25, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Rialto toilet flapper pulled to left and does not seat
The pull mechanism can be replaced with a universal one. This isn't a free thing but there are several different length's.
Pull yours out [ simple to do - unhook - use a pair of pliers and remove the large nut inside the tank and remove]
then take it and compare with a longer one. - Or there is a chain extension if you want to go that route.
Best of it
Mar 20, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet doesn't flush hard enough and some "particles" remain and need to be flushed a second time.
check water level in tank if low adjust float to proper level inside tank will see a level line also check flap as to opening all the way may have to adjust chain if problem continues hard water can cause build up in water holes and narrow tank to bowl tube
Oct 07, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Can not remove toilet seat from Kohler Rialto
to access the nut remove the tank lid, then go down and forward, its there.
Jul 03, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Jun 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Home Logo
85 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
