Question about Microsoft MSN Messenger Connect Service
I want to delete my msn messenger. - Microsoft MSN Messenger Connect Service
UNBLOCK MSN
but there are three ways to unblock msn messenger
-registry
-Microsoft management Controll
-adjusting the port range or blocking a sertain port msn =1863 (i'cant explain this because this is pretty hard, and complicated
you can get to the first 2 'apps' or programs by going to run under the start menu
if you would want to go to the Microsoft Management Controll you need to type in 'gpedit.msc' then you need to go to computer configuration/security settings/software resrictions/additional rules if a path is listed there with the name msn messenger in it delete it,
next step
computer configuration/ administrative templates/ windows components/(windows) messenger, check if these ar both turned on not configured or disabled
repeat these steps under user configuration.
if it still doesn't work
go to run
type in regedit
go to HKEY_LOCAL_MACHINE/software/policies/microsoft/messenger/client
check if preventrun and preventautorun ar set to '0'
Nov 11, 2010 | Microsoft MSN Messenger Connect for...
Msn hacked sendin my 12 yr old nasty messages
Contact MSN directly. They can delete your ID or change the password.
Jul 17, 2010 | Microsoft MSN Messenger Connect Service
How do i know when my friends have me block or are on invisible while they online?
There are various web application that is able to reveal invisible Yahoo Messenger user, XEEBER and Invisible scanner are the better ones in the market, its free!As for MSN Messenger, there is only one tool available, the Show Invisible MSN Messenger Status detector, it reveals, finds, and detects you and your contact lists MSN information and inform you all you want to know about your contacts. For example which person deleted or blocked you.
For those who are curious about which of his/her friends deleted or blocked them, do give the service a try but be cautious, I believe the tool is meant to be some sort of email harvesting application or another email hijacking tool created by spammers. Give it a try but remember to change your password as soon as you’re done with it.
Rule number one, never reveal your password to other company besides the original service provider.
Here is a cool little MSN Name Trick that allows you to have an invisible MSN Screen Name. This nickname trick should work for most versions of Messenger (ie MSN 6, 7.5, 8.0). Just follow these instructions:
  • Open the Options window so you can change your MSN Name
  • Hold down ALT on your keyboard and type in 0160 using the Numeric Keypad (usually on the right side of your keyboard)
  • Click OK to save your new Invisible MSN Name!
May 29, 2010 | Microsoft MSN Messenger Connect Service
Hello sir i cann't sign in to msn messanger whenever i try to sign in is shows me that windows live communication platform i think that there is a data error wlcommm.exe
1: press ctrl alt + delete
2: select the task manager
3: search for all related messenger programs/tasks
4: end them
5: restart messenger
good luck ; )
Apr 22, 2010 | Microsoft MSN Messenger Connect Service
Anybody can help me with this? When i try
Solutions to MSN Error Code 81000306 1) Wait for MSN to repair their Server! Meanwhile check the status of the Messenger service, at: http://messenger.msn.com/Status.aspx
2) Delete ListCache.dat
Launch CMD and navigate to %appdata%\microsoft.
CD %appdata%\microsoft
Dir /s ListCache.dat
Decide if you want to delete the cache.
Del /s ListCache.dat
Restart your MSN Messenger.
3) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger.
It would do no harm to also use regsvr32 to re-register: wintrust.dll, initpki.dll, Rsaenh.dll Mssip32.dll and Cryptdlg.dll. Here is the command string to register these dlls. Launch the 'Run' command and paste:
regsvr32 softpub.dll Wintrust.dll Initpki.dll Rsaenh.dll Mssip32.dll Cryptdlg.dll
4) Another problem could be firewall related, thus try temporarily disabling the firewall. If this cures the problem, make sure that MSN Messenger is allowed full access through the firewall.
Your problem could also be related to Error Code 80048820
5) If other people can access the MSN Messenger service, and you are the only one getting Error Code 81000306, then you could look at your anti-virus software. Has anything changed recently?
6) One more thought, could your account be locked out? Try another account if have one, or can create a new account.
Dec 08, 2009 | Computers & Internet
Can't sign in Error message 8e5e0408
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope I helped MSN expert Dr Reed
Nov 05, 2009 | Microsoft Computers & Internet
How do i clear conversations
There are a few ways to do so depending if you are wanting to delete individual conversations or the whole history..
check out this link and see if it helps.
http://en.kioskea.net/faq/sujet-1730-how-to-clear-history-msn-messenger#delete-the-complete-history-of-the-conversations-in-msn-messenger
Oct 30, 2009 | Microsoft Windows Live Messanger
Windows Live Messenger won't let me in - Error code 81000314
2. Type "regedit"
or...
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | Yahoo Messenger
Cant sign in to MSN Messenger it says Temporary Problem when i check the service site it says its running think i deleted a file
Hi there, my name is Alex and I am here to help solve your problem
A common problem to signing in to MSN Messenger is the date and time set incorrectly. You can locate this at the bottom right hand corner of the desktop. After setting the time and date correctly, you should be able to sign in without problem.
If Messenger gives problems and the date and time are both set correctly, exit MSN Messenger and exit the icon which is located in the system bar (next to the time and date) and then open MSN Messenger again.
I hope this problem helps..... If you have any questions or more problems, please feel free to ask me.
Nov 27, 2008 | Microsoft MSN Messenger Connect for...
MSN Live is not Responding, I sign in to MSN Messenger Live and it doesn't respond. What can I do to fix this problem with MSN Messenger Live?
HEY guys!!
i had da same problem i went to google and i didnt find any way so i start finding it my way ..IF msn is not responding after 3 seconds when you signin...And if you did system restore dat what had happened to me ... i ve the answer... Go to Control panel> firewall>exception> .... IF YOU VE MORE DAN TWO WINDOWS LIVE MESSENGER CHECKED..here is da mistake ...just uncheck one and signin and see..IF its again not workin check the other one.. CAUTION: leave da msn (phone) NO NEED ........I HOPE MY ANSWER IS HELP FULL
Nov 10, 2008 | Microsoft Windows Live Messanger
Computers & Internet Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
