Question about Refrigerators
I need to know how to remove and replace the door handles on my Kenmore side by side Frig model number 106.9555752. Would prefer a site to download or read the manual on how to do this.
    President:
  • 1,796 Answers
Hi!!
To remove the door handles on your unit, all you need to do is remove the handle end caps using a small screwdriver or similar object and the two 5/16" hex-head screws. same for both doors. Click on the following link for door diagram. http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/10042576-00006.png
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 12, 2010
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Side by side frig side stops working freezer still works
The best way to solve this is to email me the models number found near bottom of the fresh food compartment door. Sears problems are difficult to solve. Fixya changed their way of solving problems and posted the people to call just below your link. The email address for me is appliancepartsse@yahoo.com. I know I can solve the problem and have been here at Fixya for 3 years and have done well until now because they change the ways I can tell you how to find and fix the problem. Good Luck and hope to hear from you, Sea Breeze the model numbers for Sears look like this 213.547895
Jun 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Broken door handle needs replacing
I assume you need a paert number for the handle. according to the model number you gave I need to know the color of the refrig in order to get you the correct part number or you can go here input your model number then find youre part yourself. just remeber your looking for your color handle to be sure and get correct one. peyton
Jan 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support...
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kennmore is freezing everything in the fridge side and it is turned down to 0
YOU HAVE A BAD FRIG. THERMOSTAT REPLACE IT,GO TO SEARS .COM CLICK ON PARTS ,PUT IN YOUR MODEL NUMBER(ON INSIDE OF FRIG. OR FREEZER WALL) AND YOU CAN GET THE PART YOU NEED,LET ME KNOW HOW YOU DO-MIKE
Oct 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
596.73502200 Refrig
easy, get the model number from inside the frig. go to sears .com put your model number in and you will get the whole diagram of your frig. and how the handles come off,i'am thinking if you don't see the screws you have a panel over them that will slide up or down to let you get to the screws ,let me know how you do-mike
Oct 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Jun 22, 2008 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
