Question about OKI B6200 Laser Printer
ERRPR 006-335 PLEASE REBOOT. CHANGED FUSER AND DRUM/TONER ALREADY. STILL GETTING ERROR WHAT IS IT.
Soulvisitor
  • 1113 Answers
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Posted on Nov 13, 2007
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Posted on Apr 25, 2008
SOURCE: OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Posted on Feb 12, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
mavreix
  • 63 Answers
SOURCE: Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Posted on Sep 22, 2009
We have put a new toner in but still we are experiencing lots of horizontal lines??
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Nov 17, 2009 | HP LaserJet P3005n Printer
I have a Brother 2170w with all lights flashing. Turning on and off does not fix problem. Help!
This is in reference to another solution on this site--please search before posting as others have already solved this problem:
Per http://www.fixya.com/support/t2462964-all_3_error_lights_flashing_4_count_go
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jul 09, 2009 | Brother HL-2040 Laser Printer
Error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Jun 26, 2009 | Office Equipment & Supplies
My nasuatec dsc 435 displays sc 440-02.I don't know what to do
That code is color drum motor lock (cmy). 440-1 is for black. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
Jun 15, 2009 | Ricoh Aficio CL7100 Printer
50.1 fuser error
Fuser error is the high voltage drum. Normally there is a blown fuse somewhere attached to it that gives the error other you could have a defective fuser unit. Dont attemt yourself it works with very high voltages +- 600V
May 12, 2009 | HP LaserJet 8150n Printer
HP Laserjet 3550 Fuser Jam Error 13.20 Had it in
You need to ask them to change the fuser..The fuser is the part of the printer that actually melts the toner onto the page. Here is a website that gives you more info on the fuser so they can't B.S. you anymore..either the fuser works or it doesn't..
http://www.theofficeguide.com/toner-cartridges/faq2.html
Please rate this solution thanks.
Mar 25, 2009 | HP Color Laserjet 3550 Printer
Images of previous page remains on the new printed page
It is either a bad drum in the toner cartridge or toner on the fuser. Try changing out the toner. If the problem remains, you'll have to get a new fuser module.
Nov 29, 2008 | HP LaserJet 1020 Printer
Sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Oct 06, 2008 | Sharp AR-M550N Copier
Have an OKI Printing Solution C5800 color printer received the following error message: Check Toner cartridge 543K Toner Sensor error - have already changed the Drum and the toner. The error will not go...
8. Restart printer.
Aug 08, 2008 | OKI Office Equipment & Supplies
Poor print quality like toner low, but toner quanity is fine.
this sounds to me like it could possibly be stemming from the fuser, this is quite common on fuser that use a thin film belt for the heat roller...
May 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
OKI B6200 Laser Printer Logo
415 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
