Question about Homelite Mighty Lite Blowervac
My homelite leaf blower started making a clicking noise then diead and will not restart
chad7houston
  • 62 Answers
SOURCE: Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
trippssmengi
  • 76 Answers
SOURCE: homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
Posted on Dec 28, 2008
  • 398 Answers
SOURCE: does homelite leaf blower take reg. gas or mix?
mmmmmmmmmiiiiiiixxxxxxxx
Posted on Mar 20, 2009
  • 885 Answers
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Posted on Nov 02, 2010
2strokeguy
  • 183 Answers
SOURCE: My Homelite Mighty Lite 26b
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Posted on Dec 21, 2010
Homelite yard broom dies when it heats up
check for blockage in the air intakes, intake and out put. if you have one with a filter check it to make sure its not clogged. Over heating starts when a vent is clogged or the blower mover needs oiling. do all work with blower unpluged.
Apr 22, 2014 | Homelite 'Yard Broom' Leaf Blower
Starting cord does not retract on my leaf blower (homelite)
take off starter mechanism, replace coil, or recoil if undamaged. then replace starter rope
May 14, 2010 | Homelite 'Yard Broom' Leaf Blower
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite yard broom starts a clicking noise then power loss. Power may come back for short bursts and clicking ceases during these times.
Suspect the blower fan is loose on the crankshaft.
Open the housing on the fan side and check mounting nut. If this is the case, remove the nut, apply one or two drops of Loctite-Thread-Locker (in the blue package) to the crankshaft threads and reinstall the nut.
Hope this helps.
Oct 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Leaf Blower won't stay running
Hey .. Did you replace the inlet screen in the carb ?
or
Either the carburetor, block behind it, or the cylinder are loose. Common Homelite problem.
Let me know ....
Mar 27, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Homelite leafa Blower Model 08010B
They also provided the address of this parts supplier:
Gardner Email Address: customerservice@gardnerinc.com Address: 3641 Interchange Road
Columbis OH 42302
614-456-4000
Sep 13, 2008 | Homelite Consumer Products MightyLite...
Homelite Mighty Lite Blowervac Logo
81 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
