Question about Canon PIXMA iP4000 InkJet Photo Printer
Pictures are faded out looking and yellowish
I tried all the cleanings, took out cartridges, put in all new, NEVER use anything but Cannon brand, tried using all the control adjustments and still nothing. I am so frustrated, I have spent at least 4 or 5 hours trying to fix it to no avail! Help!
  • lil ee Aug 25, 2008
    I have the same problem, i printed one picture and it was fine, and the very next one, without even touching anything on the printer or computer, was green/yellow. now i can't get it to go back to the way it was. i tried turning it off, going into the printer settings, using other programs to print from, all the same. how could it just stop working right in mid-printing?
  • 71 Answers
Dear you need to purchase a new print head for the printer as the head is exhausted and since its a good printer its worthy to purchase a print head.
Manoj Joseph
+91 9352008418
Posted on Jun 18, 2008
Printing faded
you need to make sure you are buying brand new ink cartridges a lot of times they refill ink cartridges and this will happen also make sure you aligine and try to clean them under printer settings.
Aug 29, 2013 | Office Equipment & Supplies
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
I have a MFC290C printer. I put a new black cartridge in and you can't see the printing. It looks very faded. Is there anything I can do to get it to look brighter. Can I clean it or something. I...
Your BROTHER printer appears to have a clogged head OR the configuration settings are set to use the minimum ink.
A clogged head It is caused by lack of use. You need to "clean" the head printer using the installed tools at the computer.
Abut the configuration, check if "Saving mode" is enable on the computer o any settings that may be using little ink on printing.
May 18, 2010 | Office Equipment & Supplies
Fading prints and new cartridge error, will not aliegn
It's possible it is the new cartridge, but it sounds more like the print heads. I had the same printer and same problems until I changed the print heads. You are better off buying American Made Printer Ink Cartridges Even If They Cost A Little Less Than Name Brands. I get mine from with a 1 year quality and satisfaction guarantee with free return shipping. I have used it once and had no hassle.
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
How can I get a clearer print? Everytime I print
Beleive it or not, sometimes a new cartridge comes with the ink clogged too, put both color cartridges over a wet towel with windows cleaner by 5 minutes, then clean both with a dry towel, try to print, if the quality print stay bad, you have to suspect the printer cartridge contacts, check if are clean (if you have to clean it, do that with the printer off), if the fail continues try to use the manufacturer warranty
Jul 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
Error light and 6 beeps upon startup, therefore the printer won't print anything.
Is the BC-21e new, or refilled?
I know Cannon brand new cost so much more, but sometimes you have to bite the bullet.
I had a Cannon Multipass C2500.
Sometimes even a new cartridge isn't good enough. I used to exchange between that one and the all black cartridge, because the all black has twice the resolution. Even with very careful handling, not touching anything metal, they still went bad.
My best suggestion, short of another expensive cartridge is to remove the cartridge, take a soft pink pencil eraser and lightly erase all the contacts on the printer and the cartridge. Look for any of the spring loaded contacts in the printer that are stuck. Do not touch the contacts on the cartridge as they are unbelievably static sensitive. If you see ink on the contacts, use rubbing alcohol and a q-tip to remove it.
Most likely though, it will take yet another cartridge with head to fix it. (That's why I gave up on mine and got a different brand.)
Apr 13, 2009 | Computers & Internet
Ink is fading fast while using brand new ink cartridges
Have you replaced the Drum or is it a BJ-Ink printer?
Nov 11, 2008 | Office Equipment & Supplies
Faded printing
Check the settings in the printer properties and see if you have selected economy print..If you have, try switching to high quality..
Jun 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My cannon pixma mp800 does not recognize the cyan ink cartridge, which is brand new.
I had same problem with yellow ink cartridge. After going thru other suggestions I found on different forums that didn't work (turning printer off and on, cleaning contacts with alcohol, taking out and putting cartridge back in several times) I finally called Canon as my printer was still under 1yr warranty, and they sent me a brand new cartridge free of charge and it works great now (even though my cartridge that was giving error mssg was almost brand new too). I think they have a lot of lemon cartridges out there.
May 09, 2008 | Office Equipment & Supplies
Cannon printer
It seems there's something wrong with the cartridge connector. Try cleaning with a soft cotton cloth soaked with alchohol or After Shave and check for the ribbon connecting the head for possible damage or cut.
Oct 04, 2007 | Office Equipment & Supplies
Canon PIXMA iP4000 InkJet Photo Printer Logo
93 people viewed this question
old marine
old marine
