Hi, I cleaned the CPU fan of the Acer M3202 (Desktop, Aspire, Phenom, AMD-3x). Now I do not find the Motherboard manual to plug back the 3-pin connector to the motherboard. I do know what is the place in the motherboard where the connector goes (it is the only free place available). However, this place has an additional row of pins. Therefore, I would very much appreciate it if you would send me the motherboard diagram so that I may plug back the CPU fan? Thanks, Joseph
  • Brett Duxbury
    Brett Duxbury Jun 04, 2017
    Hi retired_univ, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?It might be useful to state the bios number it should be on a sticker on the cmos bios chip on the motherboard
cinek79
  • 320 Answers
SOURCE: where do i connect the front panel MIC connectors in the motherboard
hi check this web
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357135&lc=en&cc=us&product=3644705&dlc=en
Posted on Aug 29, 2008
compdoctor20
  • 172 Answers
SOURCE: Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Posted on Dec 05, 2008
gotgeek2
  • 565 Answers
SOURCE: finding a cpu cooler replacement for motherboard with screwholes.
You should be able to purchase a cooler that fits your existing cooler plate.
Replacing a cooler can sometimes be a lot of work. Sometimes you have to remove the motherboard from the case and remove the cooler plate from the underside of the motherboard. Then coolers that use "just the holes" can be used. Or another (different) cooler plate can be installed that may have came with your new cooler. In my experience, the coolers that use "just the holes" (no plate) leave a lot to be desired. Plus, if you're not careful, you can damage the motherboard by applying too much force when installing the fan. If you use a new plate, don't forget to install the insulator between the motherboard and the plate, if it comes with one.
Be careful to protect against unwanted electrostatic discharge. Always touch the metal computer case before touching any parts inside the computer. Also, if you remove the mobo, take careful note of where all the wires go before disassembly.
Posted on Feb 13, 2009
adnanbhatti
  • 1188 Answers
SOURCE: is this good for a
I searched the internet and also from my experience can tell that this system is quite good. This system has all what is required by the latest gaming titles to run flawlessly.
If I would be pinpointing small issues then only would find that the hard drive needs to be at least 1 terabyte nothing else to complain.
In my opinion its quite a 'heavy' system and will sure give you an edge in modern multiplayer gaming over the internet where performance is the key to success.
Just a reminder that you should use 64 bit version of Windows on this system as a 32 bit system will not be able to use the 4GB RAM. A 64 bit system will better use the resources and you can upgrade to a higher amount if needed.
If you install a 32 bit OS it will show the total RAM as 2.5 GB and rest will be wasted. Windows 7 64 bit will be the best choice as it supports multithread, multicore CPUs and advanced graphics with DirectX 10/11.
In short I can say that this system is very much adequate for todays software/games and possibly future proof upto two years for extreme gaming. Also you can move to a better graphics card and more RAM when required. And be sure to use a adequately rated UPS/surge protector.
Posted on Mar 13, 2010
Testimonial: "thank you very helpful to get a second look i plan on getting this within the month "
  • 11800 Answers
SOURCE: Does a M2N68-AM Plus (Asus motherboard) have to
Yes, it will work, just that the fan control will be missing and the fan will run at full speed constantly.
Posted on Jun 22, 2010
Can the ACER ASPIRE AST180-UA380B run an amd phenom x4 with the bios update available?
If your motherboard manufacturer support website says that the bios update will fix it, yeah go for it, though 330W isnt a lot most pc now are about 500-600w. Flashing the bios isnt hard and only takes seconds
Jan 26, 2013 | Acer Aspire™ T180 PC Desktop
My Acer Aspire M5100 get power but will not turn on
Does the CPU fan come on ?
Does the power lead that plugs into the cpu fan on the motherboard supply the required voltage ?
This one is a bit harder and once you check it you most likely need to apply thermal paste - but is there sufficient thermal paste between the CPU and the heat sink on the CPU ?
Does the power supply box in the tower case have its fan spinning when power on ?
Is the motherboard bent ?
I have seen this one - poor installation with different sized mounting screws. When motherboard gets hot the motherboard went faulty.
Some motherboards need a rubber insulator under the screw maybe there is a short under one of the mounting screws !
Mar 12, 2017 | Acer Aspire M5100 AM5100-U5313A AMD...
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
My acer aspire M5100 getting into shudown mode
Check the temperature of the CPU in Bios. It is probably higher than the Safe temperature and it gets into shut down mode to protect itself.
Open it, detach the cooler from the CPU and clean it, detach the CPU from the socket, clean the paste from the top, put a new one, clean the socket and put everything back. It should work perfectly.
If you need further assistance, just leave a comment. Cheers
May 23, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
MY AMD PHENOM QUAD CORE HEAT SINK FAN IS NOT
First, check for dust. Compressed air works to clean it out.
Second, if the fan is not spinning at all when the computer is turned on, make sure it's plugged in - a wire should connect somewhere
If neither of those work, you may just have to look into a replacement fan, at the least, or a new heatsink/fan assembly. Make sure you get one for AM3 (as Intel sockets - usually designated with a number like 775, 1136, etc. - are secured differently.) They can run from cheap to over $100.
Apr 22, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Acer aspire m5100 has a good power supply but will not start
Try to check all the connection at the back of your pc,, try to unplug and open your cpu case,,, Maybe your Power cord is not properly installed .. find the power supply port in the motherboard and try to check it again if it is properly installed
Jan 04, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
My Acer PC make a lot of whirring noise at start
check the screws ...all the screws, from power supply to the ones from your dvd. maybe one is coming out. or the cpu cooler can have the same problem.
Nov 16, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Computers & Internet Logo
David Payne
David Payne
